Eqilibrium between ice and water
  • Thread starter chound
  • Tags
    Ice Water
In summary, when pressure is applied to ice, it will start to liquify, and the equilibrium will shift towards the water phase.
chound
164
When ice is @ eqilibrium with water, the pressure is increased, what happens to the eqilibrium?
I'm not an expert in this area, but I do know that when you apply pressure to ice, it will begin to liquify. This is the physics behind most winter sports - from skating to curling.
It shifts towards the water, and that is because the density of ice is smaller than the density of water (which is quite an exceptional feat : most materials are denser in their solid phase than in their liquid phase).
It is a consequence of a general law of thermodynamical equilibrium (which you can derive more formally, but I cannot recall its derivation off the top of my head): "any action on a system in equilibrium will shift its point of equilibrium in such a way as to oppose the change you want to apply"
So, when you increase pressure, the system can try to relieve pressure by shrinking in volume (hence shifting towards the most dense phase).
I thought pressure was inversely propotional to volume. So if u increase pressure volume should also increase to decrease the pressure
Eh, your remark makes me see how badly I formulated my proposition.
Imagine you have 2 phases F1 and F2, and imagine that the specific volume of phase F1, as a function of pressure p, is v1(p), and the specific volume of phase F2 is v2(p) ; now, assume that v1(p) is much smaller than v2(p).
The total volume of the system is V = N1 v1(p) + N2 v2(p) for a given distribution of the substance over the two phases N1 in phase F1 and N2 in phase N2, which happens to be a certain equilibrium point.
Now, when pressure is increased from p to p', one can show that in general, N1 will increase, and N2 will decrease, so that the phase with the smallest specific volume will gain in importance, hence lowering the overall volume MORE than if N1 and N2 remained constant. As such, the pressure needed to put the system in volume V' (with the changing N1 and N2), is LESS than the pressure that is needed to put the system in volume V' WITHOUT shifting the equilibrium. So it is loosely said that the increase in pressure is "resisted" by the system by shifting its own degree of freedom (the point of equilibrium N1/N2). So the shifting equilibrium will 'give in more' than you would expect if the ratios remained constant (if the equilibrium would not shift).
If you assume water and ice are both incompressible, pressure will not decrease the volume of either. In general, extra pressure means extra heat (like putting air in a tire) so you might argue that the temperature of the mix will increase and that would cause some ice to melt. You could also argue that water is denser, so increased pressure will compress the ice more...that would also tend to increase the temperature of the ice, so either way it looks like ice loses!
No, pressure does not always mean heat ; the "heat" comes from the work done by the pressure on the schrinking volume. If the volume doesn't change, then increasing the pressure does not do work. But in fact, it is the shifting in equilibrium from the ice to the water phase, which allows for some work to be done by the pressure (because of the decrease in volume, remember that water takes less volume than ice), and THIS work (the pressure times the decrease in volume) IS indeed converted into (latent) heat, to allow for a bit of the ice to melt (and to shift the equilibrium in the first place).
But that was maybe what you wanted to say too:shy:
FAQ: Eqilibrium between ice and water
What is the equilibrium between ice and water?
The equilibrium between ice and water refers to the state at which the amount of ice and water in a closed system remains constant. This means that the rate of melting of ice is equal to the rate of freezing of water, resulting in a stable balance between the two states.
How does temperature affect the equilibrium between ice and water?
Temperature plays a crucial role in the equilibrium between ice and water. At temperatures below 0 degrees Celsius, the equilibrium favors the formation of ice, while at temperatures above 0 degrees Celsius, the equilibrium favors the formation of water.
Can the equilibrium between ice and water be affected by external factors?
Yes, the equilibrium between ice and water can be influenced by external factors such as pressure and impurities. An increase in pressure or the presence of impurities can lower the freezing point of water, shifting the equilibrium towards the formation of more ice.
What happens when the equilibrium between ice and water is disturbed?
If the equilibrium between ice and water is disturbed, the system will try to reach a new equilibrium by either melting or freezing more ice depending on the direction of the disturbance. This process will continue until a new equilibrium is reached.
Is the equilibrium between ice and water affected by the amount of water present?
No, the amount of water present does not affect the equilibrium between ice and water. As long as the system is closed and the temperature remains constant, the equilibrium between ice and water will remain the same regardless of the amount of water present.
