Equal intercept on the three axes
In summary, "Equal intercept on the three axes" refers to a situation in a three-dimensional coordinate system where a geometric figure, such as a plane or line, intercepts each of the three axes (x, y, and z) at the same distance from the origin. This concept is often used in various mathematical contexts, including geometry and linear algebra, to illustrate symmetry and proportional relationships in spatial arrangements.
arham_jain_hsr
25
Find the equation of a line which passes through the point (2,3,4) and which has equal intercepts on the axes.
3-dimensional coordinate geometry
The solution in my book is as follows:
"Since the line has equal intercepts on axes, it is equally inclined to axes.
[itex]\implies[/itex] line is along the vector [itex]a(\hat i + \hat j + \hat k)[/itex]
[itex]\implies[/itex] Equation of line is [itex]\frac{x-2}{1}=\frac{y-3}{1}=\frac{z-4}{1}[/itex]"
As per my understanding, an intercept is the value of x, y or z where a line "intersects" the axes. How come in the solution does having equal "intercept" on axes imply an equal "inclination" to the axes? If my understanding is correct, I can't seem to think of any possible way a line can have an equal intercept on "all" three axes other than at 0. Am I missing something out?
arham_jain_hsr said:
Homework Statement: Find the equation of a line which passes through the point (2,3,4) and which has equal intercepts on the axes.
Relevant Equations: 3-dimensional coordinate geometry
That's what I would think.
That line given as the solution does not intersect any of the coordinate axes.
I can't see how a line can intersect all three axes, either, except at the origin. It's almost as if they were really asking about a plane with those three intercepts, and then came up with a solution that is a line. Weird...
The homework statement is badly stated, because it's trying to ask for an equation of a line in ##\mathbb{R}^3## whose projections onto the ##xy##, ##xz##, and ##yz## planes have 'equal intercepts', meaning each plane intersects two axis at equivalent values, up to but not including signs. One mistake in the statement is that 'equal intercepts' is wrong. It should be 'equal absolute values of the intercepts'. If you try to construct an intersection of three planes whose projections onto the ##xy, yz, xz## planes have equal intercepts including signs, you can prove that the three planes always intersect at a point. Also, you can show that a line with 'equal intercepts' that crosses ##(a,b,c)## has the parametric form ##(a,b,c)+(\pm1,\pm1,\pm1)t##, so technically there are ##2^3=8## correct answers. For the record, the line given by the book is an intersection of a plane that intercept the ##x## at ##-2## and the ##z## axis at ##2##, a plane that intercepts the ##y## axis at ##-1## and the ##z## axis at ##1##, and a plane that intercepts the ##x## at ##-1## and the ##y## axis at ##1##. The problem is in 3D, so you can use a 3-D grapher.
Edit: I didn't prove each of these statements, and if you want to to use them, you should prove them first, to be sure.
Well, reverse engineering, we get the solution line :
## x=2+t##
##y=3+t##
##z=4+t##
So that it's the line through ##(2,3,4)## in the direction of ##(1,1,1)##. Not sure how, what this agrees with " having equal intercept with the axes".
Likes docnet
## x=2+t##
##y=3+t##
##z=4+t##
It doesn't agree, you're right. But sometimes the poor students have to 'connect the dots' to make sense of a problem if a professor's (or a textbook's) problem doesn't make any sense as stated. It happens rarely but this case seems to be one.
Source: I'm a poor student.
Likes WWGD
And , if I did the computations correctly, the angles between the line and the xz, xy, yz axes are not all equal either.
FAQ: Equal intercept on the three axes
What does "equal intercept on the three axes" mean in geometry?
"Equal intercept on the three axes" refers to a situation in a 3D coordinate system where a plane intersects the x-axis, y-axis, and z-axis at the same distance from the origin. This means that the intercepts on the x, y, and z axes are equal.
How is the equation of a plane with equal intercepts on the three axes derived?
The equation of a plane with equal intercepts on the x, y, and z axes can be derived using the intercept form of a plane equation. If the intercepts on the x, y, and z axes are all equal to 'a', the equation of the plane can be written as \( \frac{x}{a} + \frac{y}{a} + \frac{z}{a} = 1 \), which simplifies to \( x + y + z = a \).
What is the geometric significance of a plane with equal intercepts on the three axes?
A plane with equal intercepts on the three axes is significant because it represents a symmetrical plane that equally divides the space along the x, y, and z directions. This type of plane often appears in problems involving symmetry and can simplify calculations in physics and engineering.
Can the intercept 'a' be negative in the equation of a plane with equal intercepts on the three axes?
Yes, the intercept 'a' can be negative. A negative intercept indicates that the plane intersects the respective axis in the negative direction from the origin. The equation \( x + y + z = a \) still holds, but 'a' would be a negative value.
How does the plane with equal intercepts on the three axes relate to the origin?
The plane with equal intercepts on the three axes does not pass through the origin unless the intercept 'a' is zero. If 'a' is zero, the equation of the plane becomes \( x + y + z = 0 \), which does pass through the origin. For any non-zero value of 'a', the plane will be offset from the origin by that distance along the normal vector (1,1,1).
