Equation for Centre of Gravity of a Hollow Conical Frustum
In summary, Dave seems to be trying to find a general equation for calculating the centre of gravity (COG) of a hollow conical frustum. He has found an equation for a solid conical frustum, but is unable to find a similar equation for a hollow conical frustum. He has split the frustum into a number of hollow cylinders to calculate the COG, but is looking for a more general equation. He has found an equation that can be used to calculate the COG of a hollow conical frustum, but is unsure if it is correct.
Dave442
I would like to find a general equation for calculating the centre of gravity (COG) of a hollow conical frustum.
Consider a solid conical frustum as shown below:
The COG of this shape may be derived as follows:
COG = (h/4)[(b^2+2(ba)+3a^2)/(b^2+ba+a^2)]
Unfortunately, I can't seem to determine a similar equation for a hollow conical frustum
I have been able to find the COG for a hollow conical frustum by splitting the shape up into a large number of hollow cylinders, calculating the total moment about the base axis and then divideding by the total weight. To speed things up however, I was hoping that somebody might help me determine a general equation similar to that shown above. I searched through the previous threads, but everything I found related to a either a solid conical frustum or a hollow cone.
Kind Regards,
Dave
Kind Regards,
Dave
Hi Dave! Welcome to PF! :smile:
You can find the CM by dividing the frustum into rings. Can you proceed?
Hi Pranav,
Thanks for the welcome and the response.
As I mentioned in my original post, I am able to calculate the centre of mass for a hollow conical frustum by dividing into a number of hollow rings. As this approach is quite tedious however, I was hoping that somebody might help me determine a general equation similar to that which I gave for a solid conical frustum in my original post.
Any Ideas?
Dave
Dave442 said:
Hi Pranav,
Any Ideas?
Dave
You can use the same trick of rings to calculate the COG of hollow frustum.
Btw, is your frustum open or closed at both the ends?
Start out by expressing the radius r as a function of the distance z measured upward from the base. For example, r = b at z = 0, and r = a at z = h. The differential length dl along the cone is represented by [itex]dl=\sqrt{(dr)^2+(dz)^2}[/itex]. Substitute the equation for r into this equation and obtain dl in terms of dz. The amount of mass between z and z + dz is equal to 2πrdl.
Chet
... or you can just treat the frustum as the difference of two cones. You know the CoM and mass of each cone.
Hi Guys,
I managed to derive a general equation for calculating the COG of a hollow conical frustum and have attached a pdf with the details. I think it is correct. If I calculate the COG of a hollow conical frustum using this equation I get the same value as when I split the frustum up into several hollow cylinders and calculate the COG by parts. If anyone spots any errors in the proof please let me know!
Cheers,
Dave
Edit: I have updated the attached pdf after Chet spotted a typo.
  • COG of Hollow Conical Frustum.pdf
Dave442 said:
Hi Guys,
Cheers,
Dave
Something is wrong with A. The units of the three terms in parenthesis do not match. Also, I recommend using your final result to determine the cg for the case where the wall thickness is thin and constant from top to bottom. This should be very easy to obtain by the method I recommended earlier. It should provide a check on your more general result.
Chet
Hi Chet,
Sorry about that, there was a typo in the document I attached in my previous post. I have updated the pdf and you can see that the units of the three terms in parenthesis in A do in fact match. I think the derivation is correct.
For example, consider a hollow conical frustum with the following properties:
Height = 10 m
Outer Diameter at Base = 6 m
Outer Diamter at Top = 2 m
Inner Diameter at Base = 5.5 m
Inner Diameter at Top = 1.5 m
Uniform Wall Thickness = 0.5 m
Uniform Density = 7950 kg/m3
By splitting the frustum up into 100 hollow cylinders and calculating the COG by parts I get COG = 4.111 m above the base. By substituting the properties into the equation that I derived, I get COG = 4.115 m above the base.
What do you think?
Dave
Dave442 said:
Hi Chet,
Height = 10 m
What do you think?
Dave
I think, nice job.
I took your results, and manipulated them a little more for the case of constant wall thickness. Here's what I got:
If I let rb=(ri,b+ro,b)/2 and
rt=(ri,t+ro,t)/2 and
δ=(ro,b-ri,b)=(ro,t-ri,t), I get:
A = 4δ(rb+2rt)
B = 3δ(rb+rt)
[tex]Com=\frac{h(r_b+2r_t)}{3(r_b+r_t)}[/tex]
This is the same result I get with my simple integration approach in one of my earlier posts.
Using this result and your data, I get Com = 4.11111m
Chet
Likes 1 person
Hi Chet,
Cheers for that, I wasn't 100% sure what you meant in your earlier post but I get it now - very helpful!
Thanks also for looking over my stuff, much appreciated!
Cheers,
Dave
Related to Equation for Centre of Gravity of a Hollow Conical Frustum
1. What is the equation for finding the center of gravity of a hollow conical frustum?
The equation for finding the center of gravity of a hollow conical frustum is:
h = (r1 + r2 + √(r1r2)) / 3
Where h is the distance from the top of the frustum to the center of gravity, and r1 and r2 are the radii of the top and bottom bases, respectively.
2. How is the equation for the center of gravity of a hollow conical frustum derived?
The equation is derived by finding the individual centers of gravity for the frustum's top and bottom cones, and then using the concept of parallel axis theorem to combine them into one overall center of gravity.
3. Can the equation for the center of gravity of a hollow conical frustum be used for any size frustum?
Yes, the equation can be used for any size frustum as long as the dimensions (radii and height) are known.
4. How does changing the dimensions of a hollow conical frustum affect its center of gravity?
Changing the dimensions of the frustum, specifically the radii and height, will change the position of the center of gravity. As the frustum becomes taller or wider, the center of gravity will move further away from the top towards the middle of the frustum.
5. Why is it important to know the center of gravity of a hollow conical frustum?
Knowing the center of gravity is important for engineering and design purposes. It helps determine the stability and balance of the object, which is crucial for its proper functioning and safety. It also aids in the placement of supporting structures or attachments, such as handles or wheels, to ensure the frustum remains stable and does not tip over.
