Equation for lines that are tangents to a circle
In summary, the student is trying to find an equation that will give a family of straight lines that are tangents to the circle x^2+y^2=a^2 where a is a constant. He comes up with y=\pm(\frac{b(x+b)}{\sqrt{a^{2}-b^{2}}}+\sqrt{a^{2}-b^{2}}) which reduces to y=\pm\frac{bx+a^{2}}{\sqrt{a^{2}-b^{2}}} and finds a differential equation whose solution is this family of straight lines. He then tries to use the equation without extra stuff attached to it and gets
df606
Find a differential equation whose solution is a family of straight lines that are tangents to the circle [tex]x^2+y^2=a^2[/tex] where a is a constant.
So actually I'm stuck on the first part, coming up with such an equation. After some work I came up with
[tex]y=\pm(\frac{b(x+b)}{\sqrt{a^{2}-b^{2}}}+\sqrt{a^{2}-b^{2}})[/tex]
(b varies from -1 to 1 to produce the different straight lines)
which reduces to
[tex]y=\pm\frac{bx+a^{2}}{\sqrt{a^{2}-b^{2}}}[/tex]
and finding a differential equation whose solution is this family of straight lines is making my head hurt. Before I keep working I want to make sure this looks right. Graphing the equation works, but perhaps I'm misunderstanding the question.
This is different to the equation I obtain. I first started by differentination of the circle equation to obtain:
[tex]
\frac{dy}{dx}=-\frac{\alpha}{\beta}=\pm\frac{\alpha}{\sqrt{a^{2}-\alpha^{2}}}
[/tex]
The above is the tangent of the line hitting the circle at the point [itex](\alpha ,\beta )[/itex], now what you have to do is construct the line with the above tangent vale to get the equation of the tangent line.
They could just mean, differentiate the equation of a circle twice?
The answer is
[tex]y=xy'\pm a\sqrt{(y')^2+1}[/tex]
I wish I could just differentiate twice cause that makes things so much easier but I can't.
I used the equation you got as the slope for my line. That gives you a line that has the right slope but it doesn't intersect the circle at the right spot. The extra stuff in my equation moves the line around so it intersects the circle when their slopes are equal. I guess what I should be asking is, is that necessary? I'll try using the equation without extra stuff attached to it and see what I get.
Edit: Never mind, I got it, the formula was right, I was just going at it with the wrong approach. I kept squaring both sides to get rid of the ± because of some phobia I have of them, and once I stopped doing that, the problem became much simpler. I realized this after six pages of work...
FAQ: Equation for lines that are tangents to a circle
What is the equation for a line that is tangent to a circle?
The equation for a line that is tangent to a circle is y = mx + b, where m is the slope of the line and b is the y-intercept. This equation represents a straight line that touches the circle at only one point, known as the point of tangency.
How do you determine the slope of a tangent line to a circle?
The slope of a tangent line to a circle can be determined by finding the derivative of the circle's equation at the point of tangency. This derivative represents the slope of the circle's tangent line at that specific point.
Can a line be tangent to a circle at more than one point?
No, a line can only be tangent to a circle at one point. This is because a tangent line must touch the circle at only one point and have the same slope as the circle's curve at that point.
How is the equation for a tangent line to a circle related to the circle's radius?
The equation for a tangent line to a circle is related to the circle's radius in that the distance from the center of the circle to the point of tangency is equal to the length of the radius. This means that the tangent line is perpendicular to the radius at the point of tangency.
Is there a general equation for finding the tangent line to any circle?
Yes, the general equation for finding the tangent line to any circle is y = mx + b, where m is the slope of the tangent line and b is the y-intercept. This equation can be used for any circle, but the specific values of m and b will vary depending on the circle's radius and center.
