What Does the Graph of Ek,max(f) = hf - E0 Look Like?
  • Thread starter carl
  • Tags
    Graphs
In summary, an equation graph is a visual representation of a mathematical equation that shows the relationship between input and output values. To create one, you identify the independent and dependent variables and plot points to connect and form a graph. The purpose of an equation graph is to understand the behavior of the equation and make predictions. Any type of equation can be graphed and they have practical applications in various fields.
carl
the maximum kinetic energy of a photoelectron, Ek,max , to the smallest amount of energy, E0, needed to free an electron from the metal, and the energy, Eph , of the incident photons of light:
Ek,max = Eph – E0
In addition, you know from Equation 10.1 that Eph = hf where h is the Planck constant and f is the frequency of the incident light.
Which one of the following graphs represents the relationship between Ek,max and f ?
attachment of graphs is attached.
thanks trigger.
What does the graph of Ek,max(f) = hf - E0 look like?
FAQ: What Does the Graph of Ek,max(f) = hf - E0 Look Like?
1. What is an equation graph?
An equation graph is a visual representation of a mathematical equation. It shows the relationship between the input values and the output values of the equation.
2. How do you create an equation graph?
To create an equation graph, you first need to identify the independent variable and the dependent variable in the equation. Then, you can plot points by choosing values for the independent variable and solving for the dependent variable. These points can then be connected to create a graph.
3. What is the purpose of an equation graph?
The purpose of an equation graph is to visually represent the relationship between two variables in a mathematical equation. It can help to understand the behavior of the equation and make predictions about the values of the variables.
4. What types of equations can be graphed?
Any type of equation can be graphed, including linear equations, quadratic equations, exponential equations, and more. As long as there are two variables in the equation, it can be represented on a graph.
5. How can an equation graph be used in real-world applications?
Equation graphs have many practical applications in fields such as physics, engineering, economics, and more. They can be used to model and analyze real-world situations, make predictions, and solve problems.
