MHB Equation of a Circle in the Complex Plane
shen07
Hi Guys can you please help me out for the following question:
Show that the equation of the circle $$\gamma(a;r)$$ centered at $$a\in\mathbb{C}$$ and radius $$r$$ can be written in the form:
$$|z|^2 - 2Re(\bar{a}z) + |a|^2 = r^2 $$
Re: Equation of a a Circle in the Complex Plane
Have you tried taking a generalized equation for a circle in the Cartesian plane, and then converting that into Polar Coordinates...? ;)
A comparison of that and your complex form above might help...
Consider a second coordinate system centered at $a$. The variable $z'$ will range over points in that system while $z$ will range over points in the original system. Then $z=z'+a$ (e.g.., the center $z'=0$ of the second system is mapped to $z=a$).
The equation of the required circle in the second system is $|z'|^2=a^2$. Express $z'$ through $z$ and substitute it into this equation. Then use the following properties.
$|z|^2=z\bar{z}$
$2\operatorname{Re}z=z+\bar{z}$
$\overline{z_1z_2}=\bar{z}_1\bar{z}_2$
$\bar{\bar{z}}=z$
Let $$z=x+iy ,
a=s+it $$
Then the equation of the circle can be written as
$$|z-a|=r$$
$$(x-s)^2+(y-t)^2=r^2$$
$$x^2+y^2-2xs-2yt +t^2+s^2=r^2$$
Evgeny.Makarov said:
$|z|^2=z\bar{z}$
$\operatorname{Re}z=z+\bar{z}$
$\bar{\bar{z}}=z$
$$2 \text{Re}(z)=z+\bar{z}$$
$$z=\bar{z} \,\,\, z\in \mathbb{R}$$
Suppose $z = x+iy, a = h+ik$.
Note that: $\overline{a}z = (h-ik)(x+iy) = (hx+ky) + i(hy-kx)$, so that:
$\mathfrak{Re}(\overline{a}z) = hx+ky = xh+yk$.
In $\Bbb R^2$, the equation for a circle of radius $r$ centered at $(h,k)$ is:
$(x - h)^2 + (y - k)^2 = r^2$, so, expanding this, we have:
$x^2 - 2xh + h^2 + y^2 - 2yk + k^2 = r^2$
$x^2 + y^2 - 2(xh + yk) + h^2 + k^2 = r^2$
$|z|^2 - 2\mathfrak{Re}(\overline{a}z) + |a|^2 = r^2$.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
