Equation of both lines that are tangent to the graph y=x^2
In summary, the question is asking for the equations of two tangent lines to the graph of f(x)=x^2 that pass through the point (1,-3). The approach suggested involves taking the derivative of the function and using the point-slope equation to find the slope of the tangent lines. Another approach is possible without using gradients, but it is not mentioned as it has not been taught in the calculus class.
francis21
Question: Determine the equations of both lines that are tangent to the graph of f(x) = x2 and pass through point (1,-3).
Some of the equations that I could use for this problem are:
y-y1=m(x-x1) (Point-slope Equation)
the derivative of the function f(x) from first principles (the limit of the difference quotient, as h approaches 0)
First, I took the derivative of the function x2.
As a result,
f`(x) = 2x
But I'm not sure on how to go from here.
Lets say that the line is tangent to the curve at the point with coordinates (p,p2). Using the definition of the gradient of a line along with the fact that we know it passes through (1,-3) as well as (p,p2):
[tex]m = \frac{\Delta y}{\Delta x} = \frac{p^2+3}{p-1}[/tex]
Since we know that the line is tangent to the curve with equation y=x2, whose derivative, as you noted, is y'=2x, it should be clear that the slope of the line can also be expressed as m=2p, since we originally defined the point (p,p2) as the point of tangency.
Can you go from there?
Hey, thanks for the reply.
But is there another approach to this problem, without the use of gradients (since it has not been taught yet in my calculus class)? Sorry about that. That's why, it's hard to recognize what you're trying to explain.
By gradient, danago just means slope.
FAQ: Equation of both lines that are tangent to the graph y=x^2
What is the equation of a line tangent to the graph y=x^2 at a given point?
The equation of a line tangent to the graph y=x^2 at a given point (a, a^2) is y=2ax-a^2.
How do you find the points where two lines are tangent to the graph y=x^2?
To find the points where two lines are tangent to the graph y=x^2, you need to solve the system of equations y=x^2 and y=2ax-a^2. This will give you the x-coordinates of the points of tangency. You can then plug these values into the equation y=x^2 to find the y-coordinates.
Can there be more than two lines tangent to the graph y=x^2?
No, there can only be two lines tangent to the graph y=x^2 at any given point. This is because the graph of y=x^2 is a parabola, and a parabola can intersect a line at most twice.
How do you know if a line is tangent to the graph y=x^2?
A line is tangent to the graph y=x^2 if it intersects the graph at only one point and has the same slope as the graph at that point. This can also be determined algebraically by setting the equation of the line equal to the equation of the graph and solving for the point of intersection.
Can you use calculus to find the equation of a line tangent to the graph y=x^2?
Yes, you can use calculus to find the equation of a line tangent to the graph y=x^2. You can take the derivative of the graph y=x^2, set it equal to the slope of the tangent line, and then solve for the x-value of the point of tangency. This x-value can then be plugged into the equation y=x^2 to find the y-value and complete the equation of the tangent line.
