MHB Equation of Circle Through Origin
  • Thread starter Thread starter mathdad
    Circle Origin
The equation of a circle centered at (3,5) that passes through the origin (0,0) is derived using the distance formula. The distance from the origin to the center (3,5) is calculated as √34, which serves as the radius. Consequently, the equation of the circle is (x - 3)² + (y - 5)² = 34. This follows the standard form of a circle's equation, where the distance from the center to any point on the circle remains constant. Understanding the relationship between the center, radius, and points on the circle is crucial for solving such problems.
mathdad
Find the equation of the circle passing through the origin and centered at the point (3,5).
Origin means the point (0,0).
From the previous example, I found the equation of the circle centered at (3,5) to be (x - 3)^2 + (y - 5)^2 = 25.
I do not understand what part the origin plays here. The textbook does not give an example for this question. Must I find the distance from the origin to the point (3,5)?
Must I find the slope? Can I get a hint?
Mathematics news on Phys.org
Since the circle passes through the origin, then the distance from the origin to the center must be the radius. Now you have the radius, and the center was given, so stating the circle's equation will follow from that. :)
d = sqrt{(3-0)^2 + (5-0)^2}
d = sqrt{3^2 + 5^2}
d = sqrt{9 + 25}
d = sqrt{34} = radius = r
The equation must be (x - 3)^2 + (y - 5)^2 = [sqrt{34}]^2, which becomes (x - 3)^2 + (y - 5)^2 = 34.
Correct?
One definition for a circle is the locus of all points $(x,y)$ whose distance from some central point $(h,k)$ is the same, which is called the radius, and we'll label this radius $r$. Thus, the distance formula gives us:
$$r=\sqrt{(x-h)^2+(y-k)^2}$$
And upon squaring, we obtain the familiar equation for a circle in standard form:
$$(x-h)^2+(y-k)^2=r^2$$
So, if we are given the center $(h,k)$ and one point $\left(x_1,y_1\right)$ said to be on the circle, then by definition, we know the distance between the center and the given point on the circle must be $r$.
d = sqrt{3^2 + 5^2}
d = sqrt{9 + 25}
Correct?
Yes, that's correct. :)
This is very interesting. Thanks for the information...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
