Equation of dielectric polarization & net electric field
In summary, the conversation discusses the circular dependency between polarization density and electric field in a linear isotropic homogeneous dielectric. The equation for polarization density depends on the electric field, which in turn depends on the polarization density. This self-consistent calculation can be solved for simple geometries, but can become complex for non-uniform fields and polarization.
OnAHyperbola
29
In a linear isotropic homogeneous dielectric,
P
= χε0*E,
where E is the net electric field from the effects of both free and bound charges.
But E=(σfreeP)/ε0
So E itself depends on P.
My concern is, isn't this circular? How can the polarization density depend on a field that itself depends on it? Shouldn't it depend on the original field between the conducting plates, E0, given by
E0free0 ?
At a surface boundary, you get polarization surface polarization charge density ## \sigma_p= \vec{P} \cdot \hat{n} ## where ## \hat{n} ## is the outward pointing unit vector normal to the surface. This is a result of the equation ## -\nabla \cdot P=\rho_p ## for polarization charge density. The surface charge density that arises depends on P which depends on the internal E and the surface charges that arise can affect the internal E. Yes, it is a self-consistent mathematics that is needed to solve this. For some simple geometries, ( in cases where you get a uniform ## P ## from a uniform applied field ##E_o ##), ## E_i=E_o-(C)(P)/\epsilon_o ## where ## E_o ## is the applied field and ## E_i ## is the field in the material, with C being a factor that depends upon the geometry. Since ## P=\chi \epsilon_o E_i ##, (using mks units), ## E_i ## can be found in terms of ## E_o ## and ## \chi ##, (simple algebraic solution), if the geometric factor C is known. For a plane slab C=1, and for a sphere C=1/3. (Not sure what letter the textbooks use for this factor C in electrostatics. For the analogous problem in magnetostatics, they usually use the letter D.) And note to prove the 1/3 factor for a sphere requires some rather complex mathematics involving Legendre Polynomials. It's a very useful result for problems involving dielectric spheres. The plane slab factor (C=1) is much more readily computed and can be calculated by using Gauss's law. For the plane slab, ## E_i=E_o/(1+\chi) ## which is essentially a screening factor of the electric field inside the material given by the normalized dielectric constant ## \epsilon/\epsilon_o =1+\chi ##. ..editing... to understand these concepts in more detail, I would suggest working the problem of the case of fixed uniform polarization ## P ## of on a material that occurs spontaneously without any externally applied field ## E_o ## . You can do this for a plane slab or for a sphere. Compute the electric field that arises in the material as a result of the surface polarization charge from the polarization ## P ##. (The polarization ## P ## has no local effect of the electric field at that point. The only sources of electric field is the surface polarization charge density that arises at the boundaries. And assume in this case the the electric field that arises does not affect the polarization ## P ##. This is a simpler case than that of a material that has ## P=\epsilon_o \chi E ## , but a good one to illustrate the concept of surface polarization charge.)
Well, one should be prepared for circular dependencies when studying electromagnetism (afterall its the circular dependency between electric and magnetic field that makes the magic of an EM wave happen) however here its not exactly circular
It is ##E=E_0-\frac{P}{\epsilon_0}## or ##E_0-E=\frac{P}{\epsilon_0}## which basically tell us that the Polarization depends on the initial and final value of E-field, it is the difference between them as we intuitively understand it pretty much...
Likes Charles Link
Just an additional comment: The self-consistent calculation such as this one is a little tricky when you first see it, but the algebra is reasonably straightforward, at least for cases where the final result is a uniform field ## E_i ## and uniform polarization ## P ##. The mathematics for self-consistent calculations can get quite cumbersome in cases where the final result is a non-uniform field with a non-uniform polarization. Things would be very simple if the applied external field ## E_o ## were the field ## E_i ## inside the material as well, but oftentimes that is not the case.
Likes vanhees71
FAQ: Equation of dielectric polarization & net electric field
What is the equation for dielectric polarization?
The equation for dielectric polarization is P = χeE, where P is the polarization, χe is the electric susceptibility of the material, and E is the applied electric field. This equation relates the induced dipole moment per unit volume of a dielectric material to the electric field strength.
How is the net electric field affected by a dielectric material?
The presence of a dielectric material in an electric field results in a reduction of the net electric field. This is because the electric field induces dipoles in the material, which create an opposing electric field. The net electric field is then the difference between the applied field and the induced field from the dipoles.
What is the role of dielectric polarization in capacitors?
Dielectric polarization plays a crucial role in capacitors by increasing the capacitance of the device. The presence of a dielectric material between the plates of a capacitor reduces the electric field and increases the charge that can be stored on the plates, resulting in a higher capacitance.
How does the dielectric constant affect the equation of dielectric polarization?
The dielectric constant, also known as the permittivity, is a measure of a material's ability to store electric charge. It is directly related to the electric susceptibility in the equation of dielectric polarization. A higher dielectric constant results in a higher electric susceptibility and therefore a stronger polarization in the material.
Can the equation of dielectric polarization be applied to all materials?
The equation of dielectric polarization is applicable to all dielectric materials, which are materials that do not conduct electricity. This includes materials such as glass, rubber, and plastic. Conductors, such as metals, have a different equation for polarization due to their ability to conduct electricity.
