MHB Equation of line in standard form
To write the equation of a line in standard form using the point (2,1) and slope m=1, the point-slope formula y - y0 = m(x - x0) is applied. Substituting the values gives y - 1 = 1(x - 2). Rearranging this equation leads to the standard form Ax + By = C. An alternative method using the definition of slope also confirms the same result, emphasizing the flexibility in approaches. Understanding these methods will aid in solving similar algebra problems effectively.
Mike
I am having trouble with algebra... I have to write an equation in standard form containing the given point and having the give slope for (2,1);m=1
I have no clue what I am doing and am not able to find anything online. Please help
Mathematics news on Phys.org
Hi Mike,
Welcome to MHB! (Wave)
There is something called the "point-slope" form of a line. It looks like this. [math]y-y_0=m(x-x_0)[/math]. $m$ is the slope and the $x_0$ and $y_0$ refer to a point $(x_0,y_0)$.
If we plug in your info we get [math]y-1=1(x-2)[/math]. Can you rearrange that and put it into standard form?
Jameson
Hello and welcome, Mike!
Let $\displaystyle (x,y)$ be a general point on the line (other than the given point (1,2)). Using the definition of slope, we may write:
$\displaystyle m=\frac{\Delta y}{\Delta x}=\frac{y-1}{x-2}=1$
Note: using the point-slope formula will give us the same result, and more quickly (and once you are familiar with this formula, it is the way to go here), but I wanted to show you an alternate route, and if you think about it, you can see that this is a way to actually derive the point-slope formula.
$\displaystyle \frac{y-1}{x-2}=1$
Now, what should you do first to try to get this into the form:
$\displaystyle Ax+By=C$?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
