Equation of line parallel to another passing through a point
In summary: Oh, it's because they are parallel? So only the coefficient of the z term changes, right?In summary, the parametric equations for a line parallel to a given line and passing through a given point can be found by using the directional vector of the given line and the given point. The resulting equations can be converted into Cartesian form by eliminating the parameter. The coefficients of the Cartesian equations will be the same as those in the original equations, except for the coefficient of the z term, which will be the opposite.
Kernul
211
Write the parametric and cartesian equations of the line passing through ##P = (-\frac{3}{10}, 0, \frac{1}{10})## and parallel to
$$r : \begin{cases}
10x + 4y - 3 = 0 \\
x + z = 0
\end{cases}$$
Since the two lines have to be parallel, that means that the two directional vectors are linearly dependent. So I first calculate the directional vector of ##r## as follow:
##\vec v_r = \begin{vmatrix}
\hat i & \hat j & \hat k \\
10 & 4 & 0 \\
1 & 0 & 1
\end{vmatrix} = (4, -10, -4)##
Now that I have the directional vector, I know that the directional vector of the line we are searching for (let's call it ##u##) has to be linearly dependent to it, so something like this: ##\vec v_u = \alpha(4, -10, -4) = (4\alpha, -10\alpha, -4\alpha)##
With this I have already an overview of the parametric form of ##u## using ##\vec v_u## and ##P##, which is:
$$u : \begin{cases}
x = 4\alpha - \frac{3}{10}t \\
y = -10\alpha \\
z = -4\alpha + \frac{1}{10}t
\end{cases}$$
I was thinking about substituting this three equations into ##r## and find ##\alpha## but I stopped because I was doing it not knowing why. If it's the right way, why should I substitute them? If not, then, what should I do after arriving at this point?
$$r : \begin{cases}
10x + 4y - 3 = 0 \\
x + z = 0
\end{cases}$$
10 & 4 & 0 \\
1 & 0 & 1
You just need a single direction vector. You could divide out a ##2## to make it simpler: ##\vec D = \langle 2,-5,-2\rangle##. You don't need the ##\alpha##.
$$u : \begin{cases}
y = -10\alpha \\
\end{cases}$$
Remember the form for a straight line: ##\langle x,y,z\rangle = \vec P_0 + t\vec D##, where ##\vec P_0## is the position vector to a point on the line and ##\vec D## is any direction vector. Recheck your equation.
Oh sorry, I messed up the equation.
So it would be like:
$$u : \begin{cases}
x = -\frac{3}{10} + 2t \\
y = -5t \\
z = \frac{1}{10} -2t
\end{cases}$$
$$u : \begin{cases}
y = -5t \\
\end{cases}$$
You can (and should) check it yourself. Does the line you found have the right direction (i.e., is it parallel to the given line)? Is there a value of t so that it goes through the given point? If you can answer yes to both questions, then you know you have the right equation.
Likes Kernul
The fact that has the right direction can be already seen from the beginning, since it's where I started. They are linearly dependent so they are surely parallel.
About the value of ##t##, I can see that only ##t = 0## would give me the point again. Is it correct?
By the way, the Cartesian form would be:
$$\begin{cases}
x + \frac{2}{5}y + \frac{3}{10} = 0 \\
- \frac{2}{5}y + z - \frac{1}{10} = 0
\end{cases}$$
$$\begin{cases}
\end{cases}$$
If you express your Cartesian solution as equations in ##x, y## and ##x, z## then would expect the coefficients to be the same as in the original equations?
I put ##t = \frac{y}{-5}## so I guess it's normal that the coefficients remained the same. But in general I actually don't know if the coefficients can be the same as in the parametric form or not.
The first equation you were given was ##10x +4y -3 =0##
The first equation you got for the parallel line after multiplication was ##10x +4y +3=0##
Is that a surprise or coincidence?
Oh, it's because they are parallel? So only the coefficient changed?
If the lines are parallel, then ##x,y,z## change in the same proportion to each other, so only the constant term changes.
For the other equation you should get ##x+z=## some constant.
If two vectors are linearly dependent, then each one is a nonzero multiple of the other. The situation is not as obvious if you have three linearly dependent vectors, where none of them is necessarily a multiple of any of the other two.
So I did do it wrong. Then I have to put ##t = \frac{x}{2} + \frac{3}{20}##. Substituting this I would get:
$$\begin{cases}
\frac{5}{2}x + y +\frac{3}{4} = 0 \\
x + z + \frac{1}{5} = 0
\end{cases}$$
Which has the same equations but with different constants.
You mean in case there were three parallel lines? Shouldn't they all be linearly dependent in order for them to be parallel? Like, having only one parameter as a difference between them. For example: ##\vec v = (a, b, c)##, ##\vec u = \alpha(a, b, c)##, and ##\vec w = \beta(a, b, c)##
Well, I wasn't talking about three parallel lines. If two (or more) vectors are parallel, then it's pretty obvious that they are linearly dependent.
It's possible for three vectors to be linearly dependent where none is a multiple of any of the others. All they have to do is lie in the same plane. For example, u = <1, 0>, v = <0, 1>, w = <1, 1>.
Yes, yes, I already knew that. Putting them that way, they would still be parallel though, right?
No, they are not parallel. Why would you think that? All three point in different directions.
If two vectors are parallel, each one is a nonzero multiple of the other, which means that they are necessarily linearly dependent. My point was that if you have three vectors, they can be linearly dependent, but no two of them have to be parallel.
Likes Kernul
Oh okay. Because I was getting confused about what I had said before.
FAQ: Equation of line parallel to another passing through a point
1. What is the equation of a line parallel to another passing through a point?
The equation of a line parallel to another passing through a point is in the form y = mx + b, where m is the slope of the original line and b is the y-intercept of the new line.
2. How do you find the slope of a line parallel to another?
The slope of a line parallel to another is the same as the slope of the original line. This can be found using the formula (y2 - y1) / (x2 - x1), where (x1, y1) and (x2, y2) are any two points on the original line.
3. Can a line be parallel to itself?
Yes, a line can be parallel to itself. In this case, the slope of the line is undefined and the equation of the line is in the form x = a, where a is the x-coordinate of any point on the line.
4. How many lines can be parallel to a given line passing through a point?
There can be infinitely many lines parallel to a given line passing through a point. This is because the only requirement for a line to be parallel is that it has the same slope as the original line.
5. How does the y-intercept of a line parallel to another passing through a point compare to the y-intercept of the original line?
The y-intercept of a line parallel to another passing through a point will be different from the y-intercept of the original line. This is because the y-intercept represents the point where the line intersects the y-axis, and a parallel line will have a different point of intersection on the y-axis than the original line.
