Equation of Motion of Mass Damper and Rotating Bar
In summary: Expert summarizerIn summary, the conversation discusses the use of the Newtonian method to derive the nonlinear equations of motion for an inverted pendulum system. The equations for the lumped mass and the rotating bar are presented, and the relationship between linear and angular acceleration is used to relate them. The result is a set of coupled equations of motion for the system.
ThLiOp
Consider the inverted pendulum system, where a uniform rigid bar of mass m and length L is elastically hinged on top of a lumped mass M. The bar is constrained by a torsional spring of coefficient kτ and the mass is constrained by a damper of coefficient c. Derive the nonlinear equations of motion for the system by the Newtonian Method.
I have drawn the FBD of each mass and got the separate equations of motion:
For mass M:
M[itex]\ddot{x}[/itex]+c[itex]\dot{x}[/itex] = F(t)
For rotating bar:
J[itex]\ddot{θ}[/itex]+k[itex]_{τ}[/itex][itex]\dot{θ}[/itex] = 0
where J = (1/3)mL[itex]^{2}[/itex], resulting in
(1/3)mL[itex]^{2}[/itex][itex]\ddot{θ}[/itex]+k[itex]_{τ}[/itex][itex]\dot{θ}[/itex] = 0
I am not sure how to relate the 2 in order to derive the nonlinear EOM. Any hints or suggestions would be greatly appreciated!
Thank you for your post. To derive the nonlinear equations of motion for this system, we can use the Newtonian method by considering the forces and torques acting on each mass and applying Newton's second law.
For the lumped mass M, we have the equation of motion:
M\ddot{x}+c\dot{x} = F(t)
For the rotating bar, we can use the moment of inertia J = (1/3)mL^{2} and the torque equation:
J\ddot{θ}+k_{τ}\dot{θ} = -T(t)
Where T(t) is the external torque acting on the bar. To relate the equations of motion for each mass, we can use the relationship between linear and angular acceleration:
a = r\ddot{θ}
Where r is the distance from the pivot point to the center of mass of the bar. Therefore, we can rewrite the equation for the bar as:
(1/3)mL^{2}\ddot{θ}+k_{τ}\dot{θ} = -rT(t)
We can then combine this equation with the equation for the lumped mass by substituting in the relationship between linear and angular acceleration:
M\ddot{x}+c\dot{x} = -rT(t)
This gives us a set of coupled nonlinear equations of motion for the system. I hope this helps. Let me know if you have any further questions or need clarification.
Related to Equation of Motion of Mass Damper and Rotating Bar
1. What is the equation of motion for a mass damper system?
The equation of motion for a mass damper system is given by m(d^2x/dt^2) + c(dx/dt) + kx = 0, where m is the mass of the object, c is the damping coefficient, k is the spring constant, and x is the displacement of the object from its equilibrium position.
2. How is a rotating bar incorporated into the equation of motion for a mass damper system?
In the case of a rotating bar, the equation of motion becomes m(d^2x/dt^2) + c(dx/dt) + kx = -mrω^2sin(ωt), where m is the mass of the object, c is the damping coefficient, k is the spring constant, x is the displacement of the object from its equilibrium position, r is the distance of the object from the axis of rotation, ω is the angular velocity of the rotating bar, and t is time.
3. What does the solution to the equation of motion represent?
The solution to the equation of motion represents the displacement of the object at any given time, as well as its velocity and acceleration. It can also be used to determine the energy and stability of the system.
4. How can the equation of motion be solved?
The equation of motion can be solved using various mathematical methods, such as differential equations, Laplace transforms, or numerical methods. The specific method used depends on the complexity of the system and the desired level of accuracy.
5. What factors can affect the equation of motion for a mass damper and rotating bar system?
The equation of motion can be affected by various factors such as the mass of the object, the stiffness of the spring, the damping coefficient, the distance from the axis of rotation, and the angular velocity of the rotating bar. The inclusion of external forces, such as gravity or friction, can also impact the equation of motion.
  • Chemistry
