Equation of Motion of sky-diver
In summary, we discussed the equation of motion for a free-falling sky-diver, which can be written as dv/dt = -g + (k/M) v^2, where v is the magnitude of the sky-diver's velocity, k is the proportionality constant for air resistance, and g is the gravitational constant. We also explored initial data and a solution to the differential equation, and found that there exists a limiting or terminal velocity, vL, such that the velocity of the sky-diver tends to vL as time approaches infinity. Finally, we determined that vL = √(mg/k).
Samantha24
A free-falling sky-diver of mass M jumps from an aeroplane and beforen he opens his parachute experiences air resistance which is proportional to the square of the magnitude of his velocity.
a) Show that the equation of motion for the sky-diver can be written as
where v is the magnitude of the sky-diver's velocity, k is the proportionality constant for the air resistance and g is the gravitational constant.
b) What initial data concerning, v(0), is consistent with the following solution
the of differential equation obtained in part (a) of this question,
v(t) = square root ((Mg/k) ((e^-At - 1/ e^-At + 1)) ;
where
A = 2* (square root gk/M)
c) Using the expression for the velocity obtained in part (b) of this question, show that there exists a limiting or terminal velocity, vL, such that
v(t) tends to vL, t tends to infinity.
What is vL?
where
a) done
b)
dv/[(k/m)v^2 - g] = 1
sqrt(m/kg)arctan(v sqrt k/mg) = t + c
arctan(v sqrt k/mg) = sqrt(kg/m)*(t+C)
v sqrt(k/mg) = tan[sqrt(kg/m)*(t+C)]
v(t) = sqrt(mg/k)tan[sqrt(kg/m)*(t+C)]
c)
vL = lim{t→∞} √(mg/k)*(e^(-At) - 1)/(e^(-At) + 1) = √(mg/k)
I can't get the exponentials. Help appreciated.
Hi Samantha! Welcome to PF! :smile:
(try using the X2 icon just above the Reply box :wink:)
Hint: what is the limit as t -> ∞ of (e-At - 1)/(e-At + 1) ? :wink:
Hey Tim :smile:
Thanks! I got it!
Related to Equation of Motion of sky-diver
1. What is the equation of motion for a sky-diver?
The equation of motion for a sky-diver is m(dv/dt) = mg - kv, where m is the mass of the sky-diver, v is the velocity, t is time, g is the acceleration due to gravity, and k is the air resistance coefficient.
2. How does air resistance affect the equation of motion for a sky-diver?
Air resistance, represented by the term -kv in the equation, acts in the opposite direction of the sky-diver's motion and decreases as the sky-diver's velocity increases. This means that as the sky-diver falls, air resistance will increase, ultimately reaching a point where it balances out the force of gravity and the sky-diver reaches a constant velocity known as terminal velocity.
3. What are the assumptions made in the equation of motion for a sky-diver?
The equation of motion for a sky-diver is based on several assumptions. It assumes that the sky-diver is falling straight down, without any horizontal motion. It also assumes that the sky-diver is a point mass, meaning that their size and shape do not affect their motion. Additionally, it assumes that air resistance is directly proportional to velocity, which is only true for objects falling at relatively low speeds.
4. How is the equation of motion for a sky-diver derived?
The equation of motion for a sky-diver is derived from Newton's second law of motion, which states that the net force on an object is equal to its mass multiplied by its acceleration. In the case of a sky-diver, the net force is the force of gravity minus the force of air resistance. By setting these forces equal to each other and solving for acceleration, we arrive at the equation of motion.
5. Can the equation of motion for a sky-diver be applied to other falling objects?
Yes, the equation of motion for a sky-diver can be applied to other falling objects as long as the assumptions and variables are adjusted accordingly. For example, for a heavier or lighter object, the mass term in the equation would need to be changed. Additionally, for objects falling in different environments with varying air resistance coefficients, the k value would need to be adjusted.
