MHB Equation of tangents and separation of variables question
ardentmed
Hey guys,
Can anyone help me out with these questions?
The first one has a positive initial value. Separation of variables and integrating gave me: |y+3| = k√[(t^2) + 1)]
Ultimately, I got k= √5 and thus y=√5√[(t^2) + 1)] - 3.
Also, for the second one, I used a similar process, found C=-1/2, and my final answer came out to be:
y=2(x^2) +2. Am I on the right track?
Any help would be much appreciated.
Thanks in advance.
For the first one, you can drop the absolute value, since your constant will account for all solutions, hence:
$$y(t)=c_1\sqrt{t^2+1}-3$$
Otherwise your work is fine. :D
For the second one, you have made an error. What did you get when you separated the variables?
I took the integral of 1/(y^2) and 1/(x^3)
-(1/y) = 1(2x^2) + C
C= -1 +1/2
C= -1/2
Thanks.
C= -1 +1/2
C= -1/2
Thanks.
$\displaystyle \begin{align*} \int{ \frac{1}{x^3} \, \mathrm{d}x} &= \int{ x^{-3}\,\mathrm{d}x } \\ &= \frac{x^{-2}}{-2} + C_1 \\ &= - \frac{1}{2x^2} + C_1 \end{align*}$
I actually got everything right up to that point. So where did I go wrong? If C= -1/2, then the final answer should be 2x^2 + 2, no?
What do you have right after you integrate?
-1 / y = - 1/(x^2) +C
And then I proceeded to solve for C.
Thanks.
Thanks.
Well, what you should actually have is:
$$-\frac{1}{y}=-\frac{1}{2x^2}+C$$
Now, let's multiply through by -1 and observing that this need not change the sign of the arbitrary constant (a constant times an arbitrary constant is still just an arbitrary constant), we have:
$$\frac{1}{y}=\frac{1}{2x^2}+C$$
Now, solve for $y$, and then use your initial condition to find $C$.
Oh, the sign doesn't change. Therefore, the final answer should be y= (2x^2) -1, correct? C=-1
No, you need to express the right side as a single ratio before inverting both sides:
$$\frac{1}{y}=\frac{1+2Cx^2}{2x^2}$$
Now, $2C$ is just an arbitrary constant, so we may write:
$$\frac{1}{y}=\frac{1+Cx^2}{2x^2}$$
Now, you can flip or invert both sides, and then find $C$. :D
Alright. Therefore, y = (2x^2)/(1/2Cx^2)
1= 2/(1+C), thus making C=1.
So,
y= (2x^2)/(1+x^2)
Correct?
Thanks again.
So,
y= (2x^2)/(1+x^2)
Correct?
Thanks again.
You have a typo in your first line...it should read:
y = (2x^2)/(1+Cx^2)
But other than that, you have the correct solution. Good job! (Yes)
