Equation related to the wave equation
In summary: I'll try to do that now.In summary, the homework statement is that if a vector field, \vec H, is defined such that its curl is zero, then it satisfies the wave equation.
fluidistic
264
Consider the following system of equations: [tex]\frac{\partial \vec H}{\partial t} -i \vec \nabla \times \vec H =0[/tex] where [tex]\vec H[/tex] is a vector field.
1)Show that [tex]\vec Y =\partial _t \vec H[/tex] satisfies the wave equation.
2)Demonstrate that if [tex]\vec \nabla \cdot \vec H=0[/tex] initially, then it remains true for all time.
The wave equation. Namely I must show that [tex]\frac{\partial ^2 \vec Y}{\partial t^2}- \triangle \vec Y =0[/tex].
1)I must show that [tex]\frac{\partial ^2}{\partial t^2}(i \vec \nabla \times \vec H)=(i \vec \nabla \time \vec H )[/tex].
I have that [tex]\frac{\partial \vec Y}{\partial t}i \vec \nabla \times \vec H=i \frac{\partial}{\partial t}(\vec \nabla \times \vec H )[/tex].
I'm not sure how to proceed... I'm really lost.
I'd like a tip.
2)None yet, will do after 1).
Thanks for any help.
Start with
[tex]
\frac{\partial \vec H}{\partial t} = i \vec \nabla \times \vec H ~~(*) [/tex]
and compute [tex]\partial/\partial t[/tex] of both sides. You can use (*) once more to relate the 2nd time derivative of [tex]\vec{H}[/tex] to the curl of its curl. This can be related by a standard identity to the sum of [tex]\nabla^2 \vec{H}[/tex] and another term that is proportional to the gradient of [tex]\nabla \cdot \vec{H}[/tex]. So [tex]\vec{H}[/tex] almost satisfies the wave equation.
If we take another time derivative, we can use (*) to get rid of the term that involved the divergence. I have a feeling that this part is relevant to part 2.
Thank you fzero.
I just don't know how to compute [tex]\frac{\partial }{\partial t}i \vec \nabla \times \vec H[/tex].
I think I could try to workout the rest (I've noticed the identity you talk about as [tex]\vec \nabla \times (\vec \nabla \times \vec H )=\vec \nabla (\vec \nabla \cdot \vec H ) - \triangle \vec H[/tex].)
fluidistic said:
Thank you fzero.
It's simple because the derivatives commute:
[tex]
\frac{\partial }{\partial t}i \vec \nabla \times \vec H = i \vec \nabla \times \frac{\partial \vec H}{\partial t} = i \vec \nabla \times ( i \vec \nabla \times \vec H ),
[/tex]
where in the last step, we used (*).
Thanks a lot fzero. I solved part 1), though I'd like a clarification about when you said "So H almost satisfies the wave equation".
I've showed (and you probably did too) that [tex]\frac{\partial \vec H}{\partial t}[/tex] satisfies the wave equation. As it is linear, any derivative is also a solution, but I'm not sure -though I strongly believe- that [tex]\vec H[/tex] also satisfies it.
So why did you use to word "almost"?
I'll try part 2) now.
[tex]\vec{H}[/tex] satisfies
[tex]
\frac{\partial^2 \vec{H}}{\partial t^2} - \Delta \vec{H} = - \nabla (\nabla \cdot \vec{H}). [/tex]
That's what I mean by "almost." Part 2 of the question addresses a condition under which [tex]\vec{H}[/tex] actually does satisfy the wave equation.
FAQ: Equation related to the wave equation
What is the wave equation?
The wave equation is a mathematical formula that describes the behavior of a wave. It is commonly used in physics, engineering, and other scientific fields to model various types of waves, such as sound waves, light waves, and water waves.
What is the general form of the wave equation?
The general form of the wave equation is: 2u/∂t2 = c22u, where u is the displacement of the wave, t is time, c is the speed of the wave, and ∇2 is the Laplace operator.
What are the main variables in the wave equation?
The main variables in the wave equation are time (t), position (x), and displacement (u). These variables are used to describe the behavior of the wave and can be manipulated to solve for various properties of the wave, such as its speed and amplitude.
What are the boundary conditions for the wave equation?
The boundary conditions for the wave equation depend on the specific type of wave being studied. However, they typically involve specifying the value of the wave or its derivative at certain points in space and time. These conditions help to determine the behavior of the wave at different points and can be used to solve for unknown variables.
How is the wave equation used in real-world applications?
The wave equation has a wide range of applications in various fields, including acoustics, optics, and seismology. It is used to study and model the behavior of waves in these areas, which can help in the design of technologies, such as medical ultrasound machines and earthquake-resistant buildings. It is also used in research to understand and predict natural phenomena, such as tsunamis and electromagnetic radiation.
