A Equation system involving InverseDigamma(Digamma(a+1)-b*k)-1
The discussion focuses on solving a system of equations involving the Inverse Digamma function for variables a and b, given constants N, E, and K. The equations include summations of n(k) defined as InverseDigamma(Digamma(a+1)-b*k)-1. Participants suggest that numerical methods using programming languages like Python, Matlab, or Mathematica are necessary for finding solutions. Pseudo-code is provided to illustrate a brute-force approach for searching optimal values of a and b within specified ranges. The conversation invites further suggestions for analytic solutions to the problem.
rabbed
How would one go about solving this for a and b given N, E and K?
n(0) + n(1) + … + n(K) = N
n(0)*0 + n(1)*1 + … + n(K)*K = E
Where n(k) = InverseDigamma(Digamma(a+1)-b*k)-1
Mathematics news on Phys.org
I think it would have to be done numerically using Python, Matlab, or Mathematica.
Mathematica has a digamma function:
https://mathworld.wolfram.com/DigammaFunction.html
and Matlab has a digamma function:
https://www.mathworks.com/help/matlab/ref/psi.html
and Python has a version of the digamma function:
https://docs.scipy.org/doc/scipy/reference/generated/scipy.special.digamma.html
Here's some pseudo code to search for the best A, B values across a range of A, B values. It's not the fastest or the best way, and the pseudo-code needs to be written in either Python, Matlab, or Mathematica to find the answer you're looking for.
Also, the means of determining closeness could be better implemented with perhaps some other distance measurement more suited to this search.
Code:
given N , E , K
A = 0
B = 0
NDIFF= max_float_value
EDIFF = max_float_value
for a in range(a_min,a_max,a_step)
    for b in range(b_min,b_max,b_step)
        for k = 0 to K:
            X = (a+1)-b*k
            NK = inverse_digamma(digamma(X))
            N2 = N2 + NK
            E2 = E2 +k*NK
        if ((N2-N)^2+(E2-E)^2) < (NDIFF^2+EDIFF^2):
            NDIFF = (N2 - N)
            EDIFF = (E2 - E)
            A = a
            B = b
print "NDIFF = " NDIFF
print "EDIFF = " EDIFF
print "A = ". A, "  B = ", B
Thanks, i'll try that.
If anyone has ideas for an analytic solution, just shoot :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
