Equation that is defined as an identity
  • Thread starter Thread starter RChristenk
    algebra-precalculus
The equation 5x - 6 = 5x - 6 is an identity, meaning it holds true for all values of x. Simplifying it to 0 = 0 does not create a contradiction; instead, it reinforces that the equation is valid for any x. The statement 0 = 0 is universally true, indicating that any value of x satisfies the original equation. There are no violations of algebraic rules in this simplification. Therefore, both forms of the equation are consistent and valid.
RChristenk
##5x-6=5x-6##
Algebraic concepts
##5x-6=5x-6## is defined as an identity because it is true for all values of ##x##.
My question is I can further simplify and arrive at ##0=0##, in which case no values of ##x## will work because the variable ##x## itself doesn't exist.
Isn't this a contradiction? Or did I violate some rule when I simplified it to ##0=0##?
RChristenk said:
Homework Statement: ##5x-6=5x-6##
Relevant Equations: Algebraic concepts
No, not a contradiction. The equation ##5x - 6 = 5x - 6## is equivalent to ##0 = 0##. Like the first identity, the second is true for any values of x. For example, if x = 5, the equation 0 = 0 is still a true statement.
Likes RChristenk, AR72 and PeroK
No. It means that any value of ##x## will work. No matter what value you set for ##x##, you always have 0 = 0.
For which values of ##x## is ##0=0## not true?
It's also true for ##x=\frac {6}{5} ##
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
