tlonster
- 12
A collar of mass m slides without friction along a circular track of radius R as
shown in THE ATTACHMENT. Attached to the collar is a linear spring with spring constant K and
unstretched length zero. The spring is attached at the fixed point A located a distance
2R from the center of the circle. Assume gravity acts down and determine (a) the differential equation of motion for the collar in terms the angle θ and (b) the reaction force exerted by the track on the collaras a function of the angle θ.
The transport theorem
F = ma
I have worked through this problem and am not confident in my answer. A second look would be much appreciated. Here's my answer:
I created reference frame E: {er, eθ, ez} at mass m such that it's position is
r = Rer
By using the transport theorem for velocity and acceleration as seen by the intertial frame I came up with:
v(m/I) = 0 + θ(dot)R[eθ]
a(m/I) = θ(double dot)R[eθ] - (θ(dot))^2R[er]
Next the forces acting on my mass are gravity, normal, and linear spring
∴Ʃ F = mg[JI] + N[er] + K(3R-0)[-er + JI]
where JI = sinθ[er] + cosθ[eθ]
when I substitute JI into my ƩF equation, set equal to ma(m/I), and drop the unit vectors, I get these two equations:
1. mgsinθ + N -3KR + 3KRsinθ = -m(θ(dot))^2R
2. mgcosθ + 3KRcosθ = mθ(double dot)R
For my equation of motion in terms of θ, I only need to use the second equation, correct? Where θ(double dot) = (mgcosθ + 3KRcosθ)/(mR)
and for the normal force (N) I just use the first equation and move everything to one side for N = -mgsinθ +3KR - 3KRsinθ -m(θ(dot))^2R
Can someone please take a look at this? I feel as though my spring force
Fs = K(3R-0)[-er + JI] is not correct, but I don't know what else it should be. Any help would be appreciated.
Thank you.
