Equations of Motion Using Newton's Method --
In summary, Newton's method is a mathematical technique used to find the roots of a function, specifically the solution to an equation of motion. It involves iterative calculations based on Newton's second law of motion. To use it for equations of motion, you need to set up the equation in the form of F(x) = 0 and use iterative calculations to approximate the solution for x. One advantage of using Newton's method is its versatility and relatively accurate solutions. However, it does have limitations, such as requiring an initial guess and potential convergence issues. To improve accuracy, you can decrease the iteration interval and refine your initial guess or combine it with other methods.
Erikono
Determine the equations of motions in terms of x and gamma.
Assume small angles and that the wheel rolls without slip. The mass of the thin homogeneous large disk
of radius 2R is 2m. The mass of the thin homogeneous inner disk of radius R is m. The rod of length 2R is massless and rigid. The two pulleys are massless.
I have attached my homework set and the problem is number 15. (I wouldn't be able to describe this very well)
We are supposed to use Newtons method.
See uploaded images for the answer and relevant equations.
See other uploaded image for my attempt at the solution.
I'm confused as to what equations from what free body diagrams I should be using. Also, I don't know if the substitutions I am making or the constraints I have set up for the problem are right.
x_1 = R*theta ( displacements for wheels on top)
x_2 = x_1 - 2R*theta - 2R*gamma
F_s1 = k(x_1 + r*theta) (spring attached to wall)
F_s2 = T_1 = k(x_1 + r*theta) (spring between pulleys)
T_2 = mg
T_2x = T_2*gamma
F_friction = ?
I also summed moments about A which is where the smaller disk makes contact with the ground.
Any help on the matter would be greatly appreciated.
  • ME357 Problem Set 3.pdf
  • Vibes#15.pdf
Thank you.
There are a few things to consider when solving this problem. First, you should draw free body diagrams for each individual element in the system (i.e. the two wheels, the rod, the two pulleys, and the two disks). This will help you identify all the forces acting on each element and how they are related to each other. From there, you can use Newton's second law (F=ma) to write equations of motion for each element in terms of x and gamma.
One important thing to note is that the two wheels are connected by the rod, so their motions are related. This means that the equations of motion for the two wheels will be similar, with some differences based on their individual masses and radii.
Additionally, you should consider the constraints given in the problem (i.e. small angles and no slip) when writing your equations of motion. These constraints will help you simplify the equations and make them easier to solve.
Once you have written the equations of motion for each element, you can use the equations to solve for the unknown variables (i.e. x and gamma). You may also need to use some of the relevant equations given in the problem (such as the relationship between displacement and angular displacement for a rolling wheel).
I hope this helps get you started on solving the problem. Good luck!
Related to Equations of Motion Using Newton's Method --
1. What is Newton's method for solving equations of motion?
Newton's method is a mathematical technique used to find the roots of a function, or in this case, the solution to an equation of motion. It involves using iterative calculations based on Newton's second law of motion to approximate the solution.
2. How is Newton's method used to solve equations of motion?
To use Newton's method for equations of motion, you need to set up the equation in the form of F(x) = 0, where F(x) represents the net force acting on an object. Then, you can use iterative calculations to approximate the solution for x, which represents the position or velocity of the object at a given time.
3. What are the advantages of using Newton's method for equations of motion?
One of the main advantages of using Newton's method is that it can be applied to a wide range of problems, including more complex equations of motion. Additionally, it can provide a relatively accurate solution, especially when using a small interval for the iterations.
4. Are there any limitations to using Newton's method for equations of motion?
One limitation of Newton's method is that it requires an initial guess for the solution, which may not always be easy to determine. Additionally, if the guess is not close enough to the actual solution, the method may not converge to the correct solution or may take a significant number of iterations to do so.
5. How can I improve the accuracy of my solution when using Newton's method for equations of motion?
To improve the accuracy of the solution, you can decrease the interval for the iterations and/or refine your initial guess. You can also use a combination of Newton's method with other numerical methods to get a more precise solution.
