MHB Equations of Sides of Square Inscribed in Circle
The discussion focuses on finding the equations of the sides of a square inscribed in the circle defined by the equation 3(x^2+y^2)=4, with one side parallel to the line x-y=7. The radius of the circle is 2/√3, leading to vertices of the square at (±2/√3, 0) and (0, ±2/√3). The sides of the square will have gradients of 1 and -1, resulting in equations y=x+k, where k can be ±2/√3. Thus, the final equations for the sides of the square are y=x+2/√3 and y=x-2/√3. Diagrams are recommended for visual clarity in such geometric problems.
DrunkenOldFool
Find the equations of the sides of square inscribed in the circle $3(x^2+y^2)=4$, one of whose sides is parallel to the line $x-y=7$.
Mathematics news on Phys.org
The circle has radius $\frac{2}{\sqrt{3}}$. Since one of the sides is parallel to $x-y=7$, another side is parallel as well and the two left are perpendicular. This gives you a clue about all four equations you need to find. :)
Let one of the side be $y=x+k$ (Note that the line $y=x+k$ is always parallel to $y=x-7$) . The half of the length of the side of square will be equal to the perpendicular distance from the origin to the line $x+k=y$.
\[\frac{l}{2}= \Bigg| \frac{0-0+k}{\sqrt{2}}\Bigg|=\frac{|k|}{\sqrt{2}}\]
The length of each side is $l=\sqrt{2}|k|$ and the diameter of the circle is $\frac{4}{\sqrt{3}}$. Also, the diagonal of a square is $\sqrt{2}$ times its length of side. Therefore
\[\sqrt{2} \times \sqrt{2}|k|=\frac{4}{\sqrt{3}}\]
From here we get two values of $k$ i.e $2/\sqrt{3},-2/\sqrt{3}$. So two sides are $y=x+\frac{2}{\sqrt{3}},y=x-\frac{2}{\sqrt{3}}$.
With problems like this, it's always good to draw a diagram (click on the diagram to embiggen it).
[graph]psuayl2bwh[/graph]
The line $x-y=7$ has gradient 1, so the sides of the square will have gradient 1 and $-1.$ The circle is centred at the origin and has radius $2/\sqrt3$, so the vertices of the square will be at the points $(\pm2/\sqrt3,0)$ and $(0,\pm2/\sqrt3).$ You want the equations of the lines with gradient $\pm1$ going through those points, and with that information you can write down the answers.
Great word!
Ackbach said:
Great word!
It comes from The Simpsons. (f)
Thank You! This was extremely helpful.
  • · Replies 81 ·
  • · Replies 59 ·
35K
