Equations that describe ideal gas processes
In summary, the conversation starts with the question about a table of equations for ideal gas processes, to which the responder provides two links and explains that all these equations are derived from the ideal gas law. The conversation then continues with a discussion about specific equations for isothermic, isobaric, and other processes, and the concept of heat capacity is brought up. The responder then provides the definition of specific heat capacity at constant volume and explains that for an ideal gas, specific heat capacity at constant pressure is equal to specific heat capacity at constant volume plus a constant value.
physea
211
Hello!
Is there a table to show the equations that describe ideal gas processes?
For example, I know for isothermic, it's P1V1=P2V2, what about the others?
Also, how are these derived? Is it from Q-W=dU? or PV=nRT?
Any help?
thanks!
Check out:
https://en.wikibooks.org/wiki/Physical_Chemistry/Thermodynamic_Processes_for_an_Ideal_Gas
https://chem.libretexts.org/Core/Ph...rmodynamics/Ideal_Systems/Ideal_Gas_Processes
It depends. Sometimes one, sometimes the other, sometimes both. For instance, can you see how you get the isothermal equation you stated?
physea said:
Hello!
Any help?
thanks!
This is a bit puzzling.
The ideal gas law equation is
pV = nRT
or
pV = NkT
Those two are the same thing and can be derived from one another.
Everything else, depending on what is kept constant, are written using that equation. For example, for isothermic reaction that you described, T is a constant, so the equation can be written as
pV = nRT = constant
meaning that the produce of p and V are constant throughout the change, i.e. p1V1 = p2V2.
For isobaric process, you have constant p, so rewriting it, you get
V/T = nR/p = constant.
This time, V and T are constants, so V1/T1 = V2/T2.
And so on. These are NOT separate equations because they are all derived from the "mother" equation, which is the ideal gas law. Asking for a table of such equations means that you do not understand that they are all from the same equation, not to mention, it may mean that you are memorizing many different forms of the same equation unnecessarily.
Zz.
Likes sophiecentaur and NFuller
pV = nRT
or
pV = NkT
pV = nRT = constant
Zz.
In addition to the ideal gas law, another equation that characterizes ideal gas behavior is dU=mCvdT
physea said:
Thanks the first link is spot on.
But it doesn't explain what Cv and Cp is, any hint?
So you are being taught ideal gas law, but you haven't gone over the concept of heat capacity?
This is very odd. What school is this?
Zz.
$$C_v\equiv \left(\frac{\partial U}{\partial T}\right)_V$$For an ideal gas, ##C_p=C_v+R##, where, in these equations, all the quantities are per mole.
Likes physea
Related to Equations that describe ideal gas processes
What are the "ideal gas laws"?
The ideal gas laws are a set of equations that describe the behavior of gases under various conditions. They include Boyle's law, Charles' law, Gay-Lussac's law, and Avogadro's law.
What is Boyle's law?
Boyle's law states that at a constant temperature, the pressure of a gas is inversely proportional to its volume. This means that as the volume of a gas decreases, its pressure increases, and vice versa.
What is Charles' law?
Charles' law states that at a constant pressure, the volume of a gas is directly proportional to its temperature. This means that as the temperature of a gas increases, its volume also increases, and vice versa.
What is Gay-Lussac's law?
Gay-Lussac's law states that at a constant volume, the pressure of a gas is directly proportional to its temperature. This means that as the temperature of a gas increases, its pressure also increases, and vice versa.
What is Avogadro's law?
Avogadro's law states that at a constant temperature and pressure, the volume of a gas is directly proportional to the number of moles of the gas. This means that as the number of moles of a gas increases, its volume also increases, and vice versa.
  • Classical Physics
  • Other Physics Topics
