Equilibrium and indicator equation
  • Thread starter haha0p1
  • Tags
    Equilibrium
In summary, the equilibrium will move to the right as the [In-] concentration increases. This is because the reaction will try to minimize the effect of the change, and so In- will be increased.
haha0p1
46
The equation for indicator is:
HIn ⇌H+ + In-
Which reaction (forward or reverse) will be preferred when I increase the Alkali.
According to me, The reverse reaction should be preferred as the reaction will try to minimize the effect of the change. Hence In- (i.e the conjugate base) will be increased as it will react with H+ to form HIn.
But the coursebook says that the position of the equilibrium will move to the right. Kindly explain why is that so?
Chemistry news on Phys.org
How would the reverse reaction minimise the effect of the change?
How is [In-] increased by reacting with H+?
Not enough information to answer. Alkali what? Alkali salt? Alkali base?
HIn ⇌H+ + In-
The question should be in the homework section. I think it is a good question, deserving some attention by chemistry teachers. I think when I first met this subject at school I felt confused, the reason being what I saw as ambiguous expressions like "the equilibrium will move to the right" I was thinking of equilibrium as weights on a lever… but never mind.
Help yourself by writing out the equation for the equilibrium constant relating [HIn] to the dissociation products molarities [H+] and [In-]. "Adding alkali" means adding something like NaOH, I.e. essentially adding OH- to the solution, which will react with H+ there, and directly or indirectly with HIn (it matters not which) to do - what? So think again through what will happen – you have got it wrong.
I think it is better to work out your own way of thinking and talking about these things (which you are likely to meet again again) rather than someone else's way of expressing it.
FAQ: Equilibrium and indicator equation
What is chemical equilibrium?
Chemical equilibrium is the state in a reversible chemical reaction where the rate of the forward reaction equals the rate of the backward reaction, resulting in no net change in the concentrations of reactants and products over time.
How is the equilibrium constant (K) defined?
The equilibrium constant (K) is defined as the ratio of the concentrations of products to the concentrations of reactants, each raised to the power of their respective coefficients in the balanced chemical equation. For a reaction aA + bB ⇌ cC + dD, the equilibrium constant expression is K = [C]^c[D]^d / [A]^a[B]^b.
What is Le Chatelier's Principle?
Le Chatelier's Principle states that if a dynamic equilibrium is disturbed by changing the conditions (concentration, temperature, or pressure), the system will adjust itself to counteract the disturbance and restore a new equilibrium state.
What role do indicators play in equilibrium reactions?
Indicators are substances that change color at a particular pH level or concentration of a specific ion, allowing scientists to determine the point at which an equilibrium has been reached in titrations or other chemical processes.
How can the equilibrium position be shifted?
The equilibrium position can be shifted by changing the concentrations of reactants or products, altering the temperature, or changing the pressure (for reactions involving gases). Adding a catalyst will speed up the attainment of equilibrium but will not shift the equilibrium position.
