Equilibrium chem lab (FeSCN2+)
In summary, the equilibrium constant (Kc) for the FeSCN2+ reaction can be calculated by dividing the concentration of the products by the concentration of the reactants, with each concentration raised to the power of its respective coefficient in the balanced chemical equation. The equilibrium of the FeSCN2+ reaction can be affected by changes in temperature, pressure, and concentration of reactants and products, as well as the addition of a catalyst or a change in the volume of the reaction vessel. In order to shift the equilibrium, the concentration of reactants or products, temperature, pressure, or presence of a catalyst can be manipulated. The blank solution in this experiment serves as a reference point for more accurate measurements, while measuring the absorbance
mill0132
Chem lab on equilibrium. We added the same amount of Fe(NO3)2 (5ml) to varying amounts of KSCN and used a given Beer's law and absorption data to calculate concentration of FeSCN2+ and then calculate the Eq. constant (K).
I calculated the Eq. constant, but I'm stuck on two follow up questions:
Consider the equation Fe+3(aq) + SCN(-)(aq) <---> FeSCN 2+
Which ion (Fe3+) or SCN (-) is never in excess? Why?
What experimental conditions are needed to ensure "all" SCN(-) is present as FeSCN2+
The intro we were given in our lab manual described the instability of Fe2+ in water (how it forms Fe3+). Also described the colors of Fe and FeSCN2+. Also defined complex ions and oxidation states.
I don't understand how I would know which ion is limiting. We used varying amounts of KSCN and kept the amount of FeNO3 consistent. The stoichiometry would indicate it's a 1:1 ratio. According to the calculations I did for one trial, I end up with fewer moles of SCN(-) at equilibrium, so does that mean it's limiting?
Any guidance on how to figure this out would be appreciated.
it is important to understand the concept of limiting reagents in a chemical reaction. In this case, the limiting reagent is the reactant that will be completely consumed in the reaction, thus limiting the amount of product that can be formed. In order to determine which ion is limiting in this reaction, you need to compare the initial amounts of Fe(NO3)2 and KSCN that were added to the reaction.
In your experiment, you added the same amount of Fe(NO3)2 (5ml) to varying amounts of KSCN. This means that the initial amount of Fe(NO3)2 is the same for all trials, but the initial amount of KSCN is different. The stoichiometry of the reaction is 1:1, meaning that for every 1 mole of Fe(NO3)2, you need 1 mole of KSCN to form the product FeSCN2+.
In order to determine which ion is limiting, you need to calculate the moles of each reactant present in the reaction. If the moles of Fe(NO3)2 is greater than the moles of KSCN, then Fe(NO3)2 is the limiting reagent. If the moles of KSCN is greater than the moles of Fe(NO3)2, then KSCN is the limiting reagent.
To ensure that all of the SCN(-) is present as FeSCN2+, you need to make sure that the reaction has reached equilibrium. This means that the forward and reverse reactions are occurring at the same rate, and there is no net change in the concentrations of reactants and products. In order to reach equilibrium, you need to maintain a constant temperature and pressure, and allow enough time for the reaction to reach equilibrium. You also need to make sure that the concentrations of reactants are not too high, as this can cause the reaction to go to completion before reaching equilibrium.
In summary, to determine which ion is limiting in the reaction, you need to compare the initial amounts of Fe(NO3)2 and KSCN. To ensure that all of the SCN(-) is present as FeSCN2+, you need to maintain constant experimental conditions and allow enough time for the reaction to reach equilibrium.
Related to Equilibrium chem lab (FeSCN2+)
1. How do you calculate the equilibrium constant for the FeSCN2+ reaction?
The equilibrium constant (Kc) for the FeSCN2+ reaction can be calculated by dividing the concentration of the products by the concentration of the reactants, with each concentration raised to the power of its respective coefficient in the balanced chemical equation. The equation for Kc is: Kc = [FeSCN2+]/([Fe3+] [SCN-]).
2. What factors can affect the equilibrium of the FeSCN2+ reaction?
The equilibrium of the FeSCN2+ reaction can be affected by changes in temperature, pressure, and concentration of reactants and products. Additionally, the addition of a catalyst or a change in the volume of the reaction vessel can also impact the equilibrium.
3. How can the equilibrium of the FeSCN2+ reaction be shifted?
The equilibrium of the FeSCN2+ reaction can be shifted by changing the concentration of reactants or products, altering the temperature or pressure, or adding a catalyst. In general, increasing the concentration of reactants will shift the equilibrium to the right, while increasing the concentration of products will shift it to the left.
4. What is the purpose of the blank (no Fe3+ or SCN-) in this experiment?
The blank solution serves as a reference point for the colorimetric measurement of the FeSCN2+ complex. By subtracting the absorbance of the blank from the absorbance of the equilibrium solution, we can eliminate any background color and obtain a more accurate measurement of the concentration of FeSCN2+.
5. Why is the absorbance of the equilibrium solution measured at two different wavelengths?
The equilibrium solution is measured at two wavelengths (one for FeSCN2+ and one for Fe3+) in order to determine the concentration of each species separately. This allows for a more accurate calculation of the equilibrium constant and avoids any interference from the other species in the solution.
  • Chemistry
  • Chemistry
31K
16K
