Equilibrium constant expression; why exponents?
In summary: I think the use of the equilibrium constant is still valuable even if it's not the determining factor in the reaction.
CuriousBanker
190
24
Hello all.
I am wondering why we raise the concentration to the exponent of the stochiometric coefficient. I understand why we take the products of reactants or products.
For instance, let me give an example to show where I am getting mixed up.
Let's say 2A +3B = 8C as a reversible reaction.
Say the equilibrium concentration of A, B, and C are all 2 moles per liter.
then the equation is 2^8 / (2^2)(2^3) = 16
But the concentration of C is the same as the concentration of A and of B...so why is the equation saying the forward reaction is way more favored? If the forward reaction is so heavily favored, why is the concentration the same as for the reactants?
Chemistry news on Phys.org
If the forward reaction were heavily favored, the equilibrium constant would be much larger than 16 for this case. It might be 100,000 or more.
I thought being over one meant forward was favored and under one meant backward was favored. But wouldn’t the concentration alone tell you which was favored?
If equilibrium is reached with nearly equal concentrations of the components, the reaction is not really favored to go in either direction. They basically coexist in that case, as opposed to being a combustible mixture that goes almost entirely into the final product(s). For this type of thing "1" is not the determining factor. Whether it is a 1 or a 16 makes little difference. The final exponent of 8 is larger than normal, but basically, if the equilibrium constant were a ## 10^{-5} ##, (or ## 10^{-8} ## etc.), it would go in the reverse direction, and a ## 10^{+5} ## would mean the forward direction would be favored. ## \\ ## An example of a case where the equilibrium constant would be on the order of unity would be if diatomic molecules like ## O_2 ## or ## N_2 ## were heated to several thousand degrees. Then you could have nearly equal amounts of ## O ## and ## O_2 ##, etc.
Then why even have the exponents at all? Seems the concentration alone tells you enough
Please read the edited additions of post 4. Meanwhile, the exponents are necessary in doing any quantitative calculations using the equilibrium constant. That is how the equilibrium concentrations are computed. I believe it is the Law of Mass Action that says the coefficients in the reaction equation are the exponents in the expression with the equilibrium constant. ## \\ ## Note: In the example I gave at the end of post 4, the equilibrium constant is a function of the temperature. ## \\ ## A very well known equilibrium constant is ## [H^+][OH^-]=1.0 \cdot 10^{-14} ## for water solutions. If you know ## [H^+] ##, you can compute ## [OH^-] ##, etc.
I have a feeling you you may be mistaking reaction quotient with equilibrium constant. They both take the same form (products over reactants, all in appropriate powers), but Q is at any moment and can take any value, while K describes equilibrium and has a single value. At equilibrium Q=K, at other points they can differ.
Likes Charles Link
With the equilibrium constant, it tells what the final results will be, but it doesn't give any information on how long it will take to reach equilibrium. If the components are not at an equilibrium concentration, I think you can always tell what direction the reaction will proceed, but you don't have any information on how quickly the process will take place. I think the OP is presently mostly learning the equilibrium part. That is usually presented before they learn about reaction rates.
All true, my statement was addressed to the OP. Sorry for the possible confusion.
I believe the answer to the original question ("why exponents") can be derived with thermodynamics. It requires a bit of knowledge about chemical potentials, Gibbs free energy and the [itex]\Delta G^0 = -RT ln(K)[/itex] dependence. Basically if
[tex]K = \frac {[A]^a[ B]^b}{[C]^c[D]^d}[/tex]
then
[tex]\log(K) = a \log([A]) + b \log([ B]) - c \log([C]) - d \log([D])[/tex]
and with some assumptions the right side can be converted into the change of an intensive property dependent on the amount of substance (yes, it is quite handwavy at this moment, as concentration is an extensive property, so you need to put a standard volume somewhere there; I don't remember details and thermodynamics is not my forte, but I am quite sure this is a general line of thinking).
Likes DrStupid and Charles Link
Related to Equilibrium constant expression; why exponents?
1. What is an equilibrium constant expression?
An equilibrium constant expression is a mathematical representation of the ratio of products to reactants at equilibrium for a given chemical reaction. It is used to describe the extent of a reaction and can be written in terms of either concentrations (Kc) or partial pressures (Kp).
2. Why are there exponents in the equilibrium constant expression?
The exponents in the equilibrium constant expression represent the stoichiometric coefficients of the reactants and products in the balanced chemical equation. They indicate the relative amounts of each substance involved in the reaction and are essential for accurately describing the equilibrium state.
3. How do the exponents in the equilibrium constant expression affect the value of the equilibrium constant?
The exponents in the equilibrium constant expression directly affect the value of the equilibrium constant. The larger the exponent, the more significant the contribution of that substance to the equilibrium constant. This means that a change in the concentration or pressure of a substance with a larger exponent will have a greater impact on the equilibrium constant.
4. Can the exponents in the equilibrium constant expression be fractional?
Yes, the exponents in the equilibrium constant expression can be fractional. This is often the case for reactions involving gases, where the exponents represent the coefficients of the partial pressures. It is also possible for the exponents to be negative, indicating the consumption of a reactant or production of a product in the reverse reaction.
5. How does temperature affect the equilibrium constant expression?
The equilibrium constant expression is affected by temperature through the value of the equilibrium constant (K). As temperature increases, the value of K may change due to the change in the rate of the forward and reverse reactions. However, the exponents in the equilibrium constant expression remain the same, as they are determined by the stoichiometry of the reaction and are not affected by temperature.
  • Chemistry
  • Chemistry
