Equilibrium distance for solar sail
In summary, the solar sail needs a mass to area ratio and a star's mass to flux ratio in order to reach equilibrium.
cyberdiver
23
This is not actually a homework assignment, but something I decided to try in my own time. I wanted to find the radius from a star at which a solar sail would be held at equilibrium (radiation pressure = gravity), given mass per unit area and stellar luminosity at a reference radius.
So I attempted the following:
Pressure of radiation and pressure of gravity are equal and opposing:
[tex]p_{radiation}=-p_{gravity}[/tex]
Subsititute radiation pressure equation and gravity equation (rho_A is areal density, E_F is energy flux):
[tex]2 \cdot \frac{E_F}{c} = -{\rho}_A \cdot g[/tex]
Substitute inverse square law equation into E_F, areal density equation into rho_A, and the law of universal gravitation equation:
[tex]2 \cdot \frac{E_{F0} \cdot (\frac{r_0}{r})^2}{c} = -\frac{m}{A} \cdot \frac{G \cdot M}{r^2}[/tex]
Attempt to make r^2 the subject:
[tex]2 \cdot E_{F0} \cdot \frac{r_0^2}{r^2} \cdot A \cdot r^2 = -m \cdot G \cdot M[/tex]
The problem here is that r^2 and r^2 will cancel out, making the equation useless. How else could I solve this problem? Does it require calculus?
You are assuming there is a particular distance where a balance is struck. Your equations are telling you something else.
Hold on. Is it because radiation pressure and gravity both follow the inverse square law, so the equilibrium is at all distances?
Yes.
Likes cyberdiver
But if the solar sail is heavy enough, it would start falling toward the star, wouldn't it?
whether the sail drifts away from the star or falls towards it will depend on its mass to area ratio and the star's mass to flux ratio. What it won't depend on is the starting position.
So the sail can only reach a state of equilibrium if its areal density is just right, otherwise it would drift?
Yes.
Likes cyberdiver
I understand now. Thank you very much!
Related to Equilibrium distance for solar sail
1. What is the equilibrium distance for a solar sail?
The equilibrium distance for a solar sail is the point at which the gravitational force from the sun is equal to the force of radiation pressure from the sun's photons on the sail. This distance varies depending on the size and shape of the sail, as well as the intensity of the sunlight.
2. How is the equilibrium distance calculated?
The equilibrium distance is calculated using the formula r = sqrt(L/S), where r is the equilibrium distance, L is the luminosity of the sun, and S is the surface density of the sail. This formula takes into account the balance between the gravitational force and radiation pressure.
3. Why is the equilibrium distance important for solar sails?
The equilibrium distance is important because it determines the optimal location for a solar sail to receive the maximum force from sunlight. If the sail is placed too close to the sun, the gravitational force will overpower the radiation pressure and the sail will be pulled towards the sun. On the other hand, if the sail is placed too far away, the radiation pressure will be too weak and the sail will not be able to generate enough thrust.
4. How does the equilibrium distance affect the performance of a solar sail?
The equilibrium distance directly affects the performance of a solar sail. If the sail is placed at the optimal distance, it will receive the maximum amount of thrust from the sunlight, allowing it to accelerate and travel faster. However, if the sail is placed too close or too far, its performance will be significantly reduced.
5. Can the equilibrium distance be changed?
Yes, the equilibrium distance can be changed by altering the size, shape, or surface density of the solar sail. A larger sail will have a longer equilibrium distance, while a smaller sail will have a shorter equilibrium distance. The shape of the sail can also affect the equilibrium distance, as a curved sail will have a different equilibrium distance than a flat sail. Additionally, changing the surface density of the sail can also impact the equilibrium distance.
