Equilibrium position of a charge between other 2 charges
In summary: The text itself here is not correct...If the two fixed charges have opposite polarities then there can be no equilibrium...There can be no equilibrium if the charges have opposite polarities.
Bedeirnur
Place a third charge q between two charges Q1 = -2Q and Q2= 3Q so they stay in electrostatic equilibrium.
Knowing that the distance between Q1 and Q2 is equal L
(KQ1Q)/(QQ1)2 = (KQ2Q)/(QQ2)2
3. The Attempt at a Solution
Let's start by saying that i know how to solve that problem, or at least how to formally solve it, there is just something i can't understand...
So, let's try to solve...
To have equilibrium |F1|=|F2|
We can say that the distance between Q1 and Q, Q1Q=x and the distance between Q2 and Q, Q2Q=(L-x)
We put the equation
(KQ1Q)/(x)2 = (KQ2Q)/(L-x)2
At the end we get x = sqrt(2)*L/(sqrt(3)-sqrt(2) ----> A positive x
And till here i get it...
But in case we put x = Q2Q and (L-x) = Q1Q , we get at the end a Negative xI can't actually understand the meaning of a negative/positive distance...
My question is, what is the real meaning of the 2 x's, why is one positive and why is one negative?
And how can i understand if the charge q that we have placed is at the left of the left charge or at the right of the right charge?
We know for example here, that the charge q MUST be in either the right purple circle or the left circle (non between the Q1 and Q2.
I note the question reads "so they stay in equilibrium". They, plural. I agree it is not possible to place a charge between two opposite charges so that it is in equlibrium. However, I also do not see how you could place a single charge between them so that neither of the two original charges experiences a force.
Well, say that the first 2 are blocked at their position, i have to place a third one, so it doesn't move...
Your answer in the first case can't be right: for x > L the charge would be pushed to the right.
You don't have a correct relevant equation. (You don't have a relevant equation at all, in fact :( ).
Your first step is also not sufficient: You want F1 + F2 = 0, or rather ##|\vec F_1 + \vec F_2| = \vec 0##, not ##|\vec F_1| = |\vec F_2|## !
I already agreed with you that there is no solution with that interpretation. Or the other interpretation.
But the equation ##|\vec F_1| = |\vec F_2|## must hold, so it is a reasonable way of finding possible solutions. Some must then be discarded because the forces add instead of cancelling. The problem here is that there is no point between the charges where the forces cancel. Do you see a solution?
I actually already said that there is No point in between where the charge may stay in equilibrium.
I just can't understand the meaning of the negative positions that you get, for example, if you put X as the distance between the higher charge and the one we have to place, we get a negative distance.
Look at x as a coordinate, not as a distance. If you have x as the coordinate in your picture wrt the postion of the negative charge, and with the postitive x-direction to the right, then a negative x means the point you found is to the left of the negatve charge.
I think we can agree that there is no F=0 point between Q1 and Q2
Choosing the positive charge as the point where x' = 0 should bring you to the exact same point, so there must be something wrong with the signs in your equations if you then get a positive x'. You should get x'= x - L
I do get the same value for x as you got.
Dear Friend, the equilibrium position only depends on the magnitude of the two charges not their polarity thus the equation will change to:
x = L sqrt (|Q1|) / (sqrt (|Q2|) - sqrt (|Q1|))
That's not true.
If the two fixed charges have opposite polarities then there can be no equilibrium position for a charge set between them: their electric fields reinforce each other everywhere on the line between them. If they have the same polarity then the field directions are opposed and an equilibrium position can be found between them.
Clearly then the location of the equilibrium position depends upon the polarities.
Your problem may be that the force one charge exerts on another is not given by kq1q2/x2. That gives the magnitude, but if you want it to give the direction then it becomes kq1q2x/|x|3.
gneill said:
That's not true.
Then the negative sign could indicate that the distance hence obtained is in the opposite direction.
How does your formula distinguish between the cases if you eliminate all polarity information by taking absolute values?
We put the equation
The negative sigh is because you chose Q1 as first charge and x as Q2Q
FAQ: Equilibrium position of a charge between other 2 charges
1. What is the equilibrium position of a charge between two other charges?
The equilibrium position of a charge between two other charges is the point at which the net electrostatic force on the charge is zero. This means that the charge is in a stable position and will not be pushed or pulled by the surrounding charges.
2. How is the equilibrium position of a charge determined?
The equilibrium position of a charge is determined by the Coulomb's law, which states that the electrostatic force between two charges is directly proportional to the product of their magnitudes and inversely proportional to the square of the distance between them. By calculating and balancing the forces on the charge, the equilibrium position can be determined.
3. Can the equilibrium position of a charge change?
Yes, the equilibrium position of a charge can change if the position or magnitude of the surrounding charges is altered. This can be caused by moving the charges, changing their magnitudes, or introducing new charges into the system.
4. What factors affect the equilibrium position of a charge?
The equilibrium position of a charge is affected by the magnitude of the surrounding charges, the distance between them, and the direction of the forces acting on the charge. Additionally, the presence of other charges in the system and any changes in their positions can also impact the equilibrium position.
5. How does the equilibrium position of a charge relate to electric potential energy?
The equilibrium position of a charge is directly related to the electric potential energy of the system. At the equilibrium position, the electric potential energy is at a minimum, meaning that the charge is in a stable state with the lowest possible potential energy. Any deviations from the equilibrium position will result in an increase in electric potential energy.
