Equilibrium problem with 5 unknowns
In summary: In other words, the angles can be resolved just by knowing the forces.Forces:W1cos Θ + W3cos ∅ = 0W1sin Θ + W3sin ∅ - W2 = 0Where W1, W2, W3 are weight components, and Θ, ∅ are angles between suspending cables.The goal is to find equations to resolve the angle components. This seems simple enough, but apparently isn't. I have attempted to substitute +/- sqrt(1 - sin2 Θ) and +/- sqrt(1 - sin2 ∅) for the cos Θ and cos ∅ components respectively, but this just ends up a huge mess. There has got
SubZer0
This is an equilibrium problem with 3 unknown forces, and 2 unknown angles. I have resolved the horizontal and vertical forces.
Horizontal components of forces:
-W1cos Θ + W3cos ∅ = 0
Vertical components:
The goal is to find equations to resolve the angle components. This seems simple enough, but apparently isn't. I have attempted to substitute +/- sqrt(1 - sin2 Θ) and +/- sqrt(1 - sin2 ∅) for the cos Θ and cos ∅ components respectively, but this just ends up a huge mess. There has got to be an easier way of resolving the angular components in these two equations.
What is an equilibrium problem? Please provide the statement of the problem as was given to you including diagrams, if any. How can we help you if we don't know what this is about?
Hi, kuruman, thanks for the reply. The problem that I'm having at the moment is just solving the two equations above for the angle component. Instead of putting all of the force diagrams, etc, I just reduced it down to a problem of solving those equations. The goal is to get two equations from those above, in order to resolve to theta and phi.
I understand what you think your problem is. Simply put, if you have two equations and five unknowns, you cannot solve for the unknowns and that's that. Now maybe, just maybe, one or more of the following is the case (a) one might be able to get additional equations relating the variables; (b) some of the variables that you think are unknown are actually known; (c) there is a special relation between variables, e.g. the angles, that reduces the number of the unknowns; (d) you misunderstood what the problem is asking; (e) there is something else that has escaped you; (f) it's a poorly phrased problem that has no solution. I have seen all of the above in posts by other people and that is why I asked you to show the complete statement of the problem. Clearly, your method led you to a dead end. We cannot help you out of this if we don't have the whole picture.
Likes PhanthomJay
One unknown can be eliminated straight away. Only the ratios between the forces will matter for the angles.
Related to Equilibrium problem with 5 unknowns
1. What is an equilibrium problem with 5 unknowns?
An equilibrium problem with 5 unknowns refers to a mathematical problem where there are 5 variables that need to be solved for in order to find a stable state where all forces and factors are balanced.
2. What are the common methods used to solve an equilibrium problem with 5 unknowns?
The most common methods for solving an equilibrium problem with 5 unknowns are the substitution method, elimination method, and graphing method. These methods involve manipulating equations and variables to solve for the unknowns.
3. Can an equilibrium problem with 5 unknowns have multiple solutions?
Yes, an equilibrium problem with 5 unknowns can have multiple solutions. This means that there can be more than one combination of values for the unknowns that will result in a balanced state.
4. What are some real-world applications of an equilibrium problem with 5 unknowns?
An equilibrium problem with 5 unknowns can be applied to various fields such as physics, chemistry, and economics. For example, it can be used to determine the optimal production levels for a company or the ideal conditions for a chemical reaction.
5. How can I check if my solution to an equilibrium problem with 5 unknowns is correct?
To check if your solution to an equilibrium problem with 5 unknowns is correct, you can substitute the values you have found back into the original equations and see if they satisfy the conditions for equilibrium. Additionally, you can use a graphing calculator to plot the equations and see if the solution point is where all lines intersect.
