rhxoehwhfh
- 91
4. When 1 kg of water at 1000C is mixed with 10 kg of water at 00C, the equilibrium temperature will be:
a) exactly 00C b) exactly 500C c) exactly 1000C d) slightly above 00C
5. Two objects, A and B, have the same mass and the same initial temperature. However, object A has a smaller specific heat capacity than object B. If the same amount of heat of heat is added to each object, then:
a) both objects will have the same final temperature
b) object A will have the higher final temperature
c) object B will have the higher final temperature
d) we need the values of the specific heat capacities to determine which object has the highest final temperature
