Equilibrium? What does this mean?
In summary, the conversation discusses the equilibrium of three charged beads fixed on a horizontal rod. The equation 0 = 3d2 - 6xd +2x2 is used to determine the distance x at which the third bead can be placed for stable equilibrium. The book states that a positive charge is required for stability, but the speaker questions if a negative charge could also work. The conversation then compares the equilibrium of a marble at the top of a hill and in a valley, and clarifies that d = 1.50m.
flyingpig
2,579
Two small beads having positive charges 3q and q are fixed at the opposite ends of a horizontal insulating rod, extending from the origin to the point D, a third small charged bead is free to slide on the rod at a distance x away from the origin (but shorter than D). Can the equilibrium be stable?
Now I broke it down to
0 = 3d2 - 6xd +2x2
Solving x = 0.951
The book said that it can be stable if it is positive. But wouldn't a negative charge also worked since
[tex]k\frac{3q*-q_{x}}{x^2} = k\frac{q*-q_{x}}{(d-x)^2}[/tex]
Negative and both sides and hence they cancel?
Consider the equilibrium situations for a marble at rest balanced at the top of a hill versus a marble at rest in a valley between hills. Are both stable equilibriums?
I forgot t mention d = 1.50m...
Related to Equilibrium? What does this mean?
1. What is equilibrium and why is it important in science?
Equilibrium is a state of balance or stability in a system. It is important in science because it allows us to understand and predict the behavior of various systems, such as chemical reactions, physical processes, and ecological systems.
2. How is equilibrium achieved in a system?
Equilibrium is achieved when the forward and reverse reactions in a system occur at equal rates, resulting in no net change in the concentrations of reactants and products. This can be achieved through various factors such as temperature, pressure, and concentration.
3. What is dynamic equilibrium and how does it differ from static equilibrium?
Dynamic equilibrium is a type of equilibrium in which the system is constantly changing, but the overall concentrations of reactants and products remain constant. This is different from static equilibrium, where there is no movement or change in the system.
4. Can equilibrium be disturbed and if so, how?
Yes, equilibrium can be disturbed by changing the conditions in the system. For example, increasing the concentration of one reactant can shift the equilibrium towards the products, while decreasing the concentration of a product can shift the equilibrium towards the reactants.
5. What are some real-life examples of equilibrium?
Some real-life examples of equilibrium include the melting and freezing of ice, the dissolution of a salt in water, and the breathing of humans. These processes reach a state of equilibrium when the rate of the forward reaction is equal to the rate of the reverse reaction.
