I Equipartition theorem and Drag
  • I
  • Thread starter Thread starter Opus_723
    Drag Theorem
The discussion centers on reconciling the generalized equipartition theorem, which suggests no correlation between canonical momentum and its rate of change, with the observed drag force on a heavy particle in a fluid. It highlights that while the theorem indicates <p(dp/dt)> should equal zero, drag forces in macroscopic systems seem to contradict this by correlating momentum with force. The conversation suggests that deriving dissipation from Hamiltonian dynamics requires statistical mechanics techniques, specifically through the Boltzmann equation and its connection to the Fokker-Planck equation. The challenge lies in understanding how the statistical nature of Langevin equations can yield nonzero <p(dp/dt)> despite the equipartition theorem's implications. Ultimately, the discussion seeks clarity on the relationship between these theoretical frameworks and their predictions regarding particle dynamics.
Opus_723
If I have a many-body Hamiltonian, and I choose a coordinate x with canonical momentum p, I can say that by the generalized equipartition theorem that
<p(dH/dx)> = -<p(dp/dt)> = 0
Since p and x are distinct phase space variables, and since by the Hamiltonian equations of motion the force (dp/dt) on coordinate x is equal to -dH/dx. So there is no correlation between a canonical momentum and its own rate of change, or the force acting on that coordinate.
On the other hand, if I imagine that my many body system is, for example, a heavy particle in a liquid or gas made of light particles, then there should be something like a drag force on the heavy particle. And a drag force is very obviously correlated with the momentum, with the force tending to be opposite the momentum. So it seems like <p(dp/dt)> should be nonzero.
Another way to see this is to simply look at the correlation in a typical Langevin equation.
So how do I reconcile the correlation between momentum and force at the more macroscopic level where we see 'drag' and the equipartition theorem telling me there should be no such correlation between a canonical momentum and its own rate of change?
To derive dissipation (friction) from Hamiltonian dynamics you need to use some "coarse graining" in the sense of statistical mechanics. One way is to start from the Liouville equation, which is still an exact description of the ##N##-particle distribution function and use it to derive the Boltzmann equation for the one-particle distribution function. Doing so, you'll see that you get first an equation of motion for the one-particle distribution function containing the two-particle distribution function, for the two-particle distribution function you need the three-particle distribution function and so on (the so-called BBGKY hierarchy). To truncate this "tower of equations" for the distribution functions you assume that you can neglect two-particle correlations and substitute the two-particle correlation function by the product of two one-particle correlation functions, i.e., you only keep the uncorrelated part. This leads to the Boltzmann equation, and the H-theorem can be derived, which shows that you have entropy production and dissipation.
With the Boltzmann equation you can also derive the Fokker-Planck equation for the motion of a "heavy particle" in a "heat bath" of "light particles", because then in each two-body collision the momentum transfer to the heavy particle is small, and you can expand the collision term of the Boltzmann equation up to 2nd order in the momentum transfer, which reduces the Boltzmann integro-differential equation to the partial differential Fokker-Planck equation, which itself is again equivalent to a Langevin process, describing the interaction of the heavy particle with the medium by a friction term and a random-force term (friction/drag=dissipation and fluctuations=diffusion).
A very good introduction can be found in Landau and Lifshitz, Course of theoretical physics, Vol. X.
Okay, that makes sense, but I'm having trouble seeing how the two pictures connect. If I measure <p(dp/dt)> for one particle, it should be zero, and yet the motion of that particle could be well described by a Langevin equation that has a nonzero <p(dp/dt)> due to the drag term. Is it just that Langevin equations get lots of statistics right but fundamentally fail to reproduce the correct <p(dp/dt)> because of the approximations involved, or am I still missing something that actually reconciles the two predictions?
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
