Equipartition Theorem Question
  • Thread starter ashworcp
  • Tags
    Theorem
In summary, the root-mean-square speed of a helium atom is equal to the root-mean-square speed of an air molecule at STP when the temperature is 34.1 degrees Celsius or 307 Kelvin. This is assuming a constant pressure and using oxygen as a comparison for air molecules.
ashworcp
Assuming that pressure remains constant, at what temperature is the root-mean square speed of a helium atom equal to the root-mean-square speed of an air molecule at STP? Express your answer to 3 significant figures in Kelvin.
the root mean square speed is given by vrms = Sqrt[3 kT/m]
where T is the temperature and m is the mass of one molecule (k is the Boltzmann constant)
so if we take ratios, we get
vrms(He)/vrms(O2) = Sqrt[T(he)/T(O2)] Sqrt[m(O2)/m(He)]
I am using oxygen since air is a mixture and there is no such thing as a molecule of air. If you need to compare an ensemble of He atoms to an ensemble of air molecules, use molecular weight = 28.97
so we have
vrms(He)/vrms(O2) = Sqrt[T(He)/273][Sqrt[32/4]
for vrms(He) = vrms()2), then
1 = (T/273)(8) => T=273/8 solve for T
So you get 34.125 C? Then going to Kevlin it would be 307.125 and rounding to 3 significant figures is 307?
Is this right??
T is the absolute temperature in K.
ehild
So it is 34.1 rounding to 3 significant figures?
Related to Equipartition Theorem Question
1. What is the Equipartition Theorem?
The Equipartition Theorem is a principle in statistical mechanics that states that, in thermal equilibrium, the total energy of a system will be equally distributed among all of its degrees of freedom.
2. How does the Equipartition Theorem relate to the kinetic theory of gases?
The Equipartition Theorem is directly related to the kinetic theory of gases as it explains the distribution of kinetic energy among the particles in a gas. According to the theorem, each degree of freedom (such as translational, rotational, and vibrational motion) will have an average energy of 1/2 kT, where k is the Boltzmann constant and T is the temperature in Kelvin.
3. Can the Equipartition Theorem be applied to all systems?
No, the Equipartition Theorem is only applicable to systems in thermal equilibrium. This means that the system must be at a constant temperature and all of its parts must be in constant interaction with each other.
4. What are some real-world applications of the Equipartition Theorem?
The Equipartition Theorem has various applications in fields such as thermodynamics, statistical mechanics, and molecular dynamics simulations. It is used to calculate the internal energy of gases, predict the heat capacity of materials, and study the behavior of molecules in different environments.
5. Are there any limitations to the Equipartition Theorem?
Yes, the Equipartition Theorem has some limitations. It assumes that all degrees of freedom in a system have the same average energy, which is not always the case. It also does not take into account quantum effects and cannot be applied to systems with very few particles or at very low temperatures.
