Equipotential of transmission or telegraph line
In summary, the conversation discusses how it is possible to have two different voltages in a single copper wire and explains that this occurs due to the propagation of voltage through the wire and the concept of equipotential lines. It also mentions that this only applies in certain conditions and with certain assumptions.
iVenky
212
Take a telegraph line or transmission line which is long. Now slowly the wave propagates through the wire in the forward direction. In the beginning one end of the wire will have a non-zero voltage while the other end will have zero voltage and it takes some more time to get settled after some reflections. Now the question is how can we have two different voltages in a single copper wire? Equipontential means that the voltage should be same everywhere in a single copper.
At equilibrium.
iVenky
You ask “Now the question is how can we have two different voltages in a single copper wire?” I answer that we do have different voltages in a single conductor all the time. If not, radio and TV would not function, among lots of other things.
In a simple dipole antenna, like a TV rabbit-ears the current distribution is roughly sinusoidal. It falls to zero at the end and is at a maximum in the middle. Conversely the voltage is low at the middle and rises to a maximum at the ends. It is generally fed at the centre, at the point where the current is at a maximum and the voltage a minimum.
Equipotential lines are like contour lines on a map which trace lines of equal electric potential or voltage. Please note that it does not apply to a conductor like an antenna or copper wire. See:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/equipot.html
Cheers,
Bobbywhy
voltage changes require a finite amount of time to propagate through a conductor. If I apply a voltage to one end of a wire the other end will be at a different potential until the charges have had time to move around and equalize the potential. The principal of equipontential can be used as a good approximation for circuits where resistance, capacitance, inductance, and the physical size of the circuit are small and/or the rate of change of voltage is slow.
iVenky said:
T Now the question is how can we have two different voltages in a single copper wire?
Adding to the other excellent responses:
Only if the resistance of the wire is zero or there is no current flowing.
*and*
We are at DC. If we have AC, then the wire has inductance and the two ends of the wire are not the same node in an equivalent circuit.
*and*
We assume zero flight time.
Related to Equipotential of transmission or telegraph line
What is an Equipotential of Transmission or Telegraph Line?
An equipotential of transmission or telegraph line refers to the imaginary line along which every point has the same electrical potential. This means that there is no potential difference between any two points on this line.
Why is it important to maintain an Equipotential of Transmission or Telegraph Line?
It is important to maintain an equipotential of transmission or telegraph line because it ensures that the electrical current is evenly distributed along the line. This helps to prevent power loss and potential damage to the line and its components.
What factors can affect the Equipotential of Transmission or Telegraph Line?
The main factors that can affect the equipotential of transmission or telegraph line are distance, resistance, and changes in the electrical load. The longer the line, the higher the resistance, and the greater the load, the more likely it is for the equipotential to be disrupted.
How is the Equipotential of Transmission or Telegraph Line maintained?
To maintain the equipotential of transmission or telegraph line, various measures can be taken such as proper insulation, regular maintenance of components, and using grounding techniques. These measures help to keep the electrical current evenly distributed along the line.
What are the consequences of an Equipotential of Transmission or Telegraph Line being disrupted?
If the equipotential of transmission or telegraph line is disrupted, it can lead to unequal distribution of electrical current, which can cause power loss, voltage fluctuations, and potential damage to the line and its components. This can result in service disruptions and potential safety hazards.
  • Classical Physics
  • Electromagnetism
  • Electrical Engineering
  • DIY Projects
  • Electromagnetism
