Equipotential surfaces for an electric dipole
In summary: The equation of the surface is just a function of q and r.It's a function of q and r.Don't worry about the z-coordinate.
vcsharp2003
897
177
Question:
Equipotential surfaces associated with an electric dipole are
a) spheres centered on the dipole
b) cylinders with axes along the dipole moment.
c) planes parallel to the dipole moment.
d) planes perpendicular to the dipole moment.
e) None of the above
None
The answer is given as (a), but I think it's not correct based on the equipotential surfaces diagram given in our book for an electric dipole as below.
The red dashed lines, which are supposed to be the equipotential surfaces, are surely not representing a sphere centred at the dipole center. So, in my view, the correct answer is "(e) None of the above".
I would agree with you. To me arguing that the equipotential surfaces of a dipole are spheres centered at the dipole is essentially saying that a dipole and a monopole are the same thing……which is insane.
Physical dipole or ideal dipole.
Likes topsquark, DeBangis21 and vcsharp2003
Ok. Thanks for your answer. One more question regarding this example. Are the equipotential surfaces for a dipole still spherical or are they some form of a conic?
That you can answer yourself using the expressions for the potential field...
:smile:
Likes topsquark and vcsharp2003
Are we talking about a physical dipole or an ideal dipole?
for an ideal dipole definitely not because the spacing is so small the equipotential lines will smoosh together.
I'd have to work it out for a physical dipole.
Likes vcsharp2003
As a guess, just by looking at the diagram, each dashed red line is definitely not a circle, so probably it would be some sort of an ellipse. And therefore, each equipotential surface would not be spherical.
Simply write down the potential ##\Phi(\vec{r})## for a dipole and check, what the surfaces ##\Phi(\vec{r})=\text{const}## are.
One knows by (anti)symmetry that the plane between them is equipotential usually chosen =0
Well, that plane can be considered a (rather big :wink:) sphere ...
  • Haha
Likes topsquark, PhDeezNutz and vanhees71
centered very far away
Likes topsquark and PhDeezNutz
This is an elaboration of post #7 by @vanhees71.
Say it is true that "spheres centered on the dipole" are equipotentials. Call the direction of the dipole ##\mathbf{\hat z}.~## You could go to distance ##r## at angle ##\theta## relative to ##z## and construct such a sphere of radius ##r## centered at the dipole. Now go to the diametrically opposing point on the sphere and see whether the potential has the same value as the starting point. It does not. In fact it is the negative of that value. That's because $$V_i=\frac{k~p\cos(\theta)}{r^2}~~\text{and}~~V_f=\frac{k~p\cos(\theta + \pi)}{r^2}=-\frac{k~p\cos(\theta)}{r^2}=-V_i.$$The two points on the surface of the sphere are not at the same potential. One can see that the only equipotential is the ##xy##-plane where ##\theta = \frac{\pi}{2}## and ##V_i=V_f=0.##
Likes topsquark, vcsharp2003, hutchphd and 1 other person
Why would that plane be a sphere? Or maybe you were just joking.
The zero potential points will lie only on the equatorial plane that bisects the dipole axis and is perpendicular to the dipole axis, since all points on such a plane will be equidistant from either +q or -q charge resulting in algebraic sum of the potentials due to +q and -q being zero.
A plane is the limit of a sphere radius r, centre at r from O, as r tends to infinity.
It is treated as a special case of a sphere in some branches of geometry, such as https://en.wikipedia.org/wiki/Inversive_geometry
I see. I never knew that. Thankyou.
BvU said:
Don't look like no spheres to me though
Quite…
##\frac 1{\sqrt{y^2+(x-a)^2}}-\frac 1{\sqrt{y^2+(x+a)^2}}=c##
##y^2+(x+a)^2+y^2+(x-a)^2-2\sqrt{(y^2+(x+a)^2)(y^2+(x-a)^2)}=c^2(y^2+(x+a)^2)(y^2+(x-a)^2)##
##2(y^2+x^2+a^2)-2\sqrt{(y^2+x^2+a^2+2xa)(y^2+x^2+a^2-2xa)}=c^2(y^2+x^2+a^2+2xa)(y^2+x^2+a^2-2xa)##
Writing ##z^2=(x^2+y^2+a^2)## and ##w^4=z^4-4a^2x^2##:
##2z^2=2w^2+c^2w^4##
Likes BvU and vcsharp2003
haruspex said:
Quite…
##2z^2=2w^2+c^2w4##
If I wanted to know the equation of the red dashed line i.e. equation of red dashed curve in two dimensions like in terms of x and y, then would I plugin z = 0 in the final form of equation of the surface you have got? If I do that then the first term on the right side would be an imaginary term.
vcsharp2003 said:
If I wanted to know the equation of the red dashed line i.e. equation of red dashed in two dimensions like in terms of x and y, then would I plugin z = 0 in the final form of equation of the surface you have got? If I do that then the first term on the right side would be an imaginary term.
My z has nothing to do with x,y,z coordinates.
Likes vcsharp2003
I see.
I did my own analysis, as shown below, to get the equation of an equipotential line that is shown in my original post ( i.e. not an equipotential surface). I end up with an equation that's impossible to interpret as being an equation of some standard curve like circle or ellipse.
… as the image @BvU linked illustrates.
Likes vcsharp2003
I see. Then, one can conclude that the red dashed line is surely neither a circle nor an ellipse. It's just some non-standard closed curve.
Right.
Likes PhDeezNutz and vcsharp2003
The point dipole potential in polar coordinates shown in post #12 is easier to handle. It is an approximation in the limit ##r=\sqrt{x^2+y^2}>>a##, i.e. for distances much larger than the separation between charges. You can get this result using a Taylor expansion of your expression for small ##a/r.##
You can make a polar plot of equipotentials, quite easily, if you have a plotting program. The relevant equation is obtained as follows $$V=\frac{k~p~\cos(\theta)}{r^2}=\text{const.}\implies r=\pm C\sqrt{\cos(\theta)}~.$$ Below are shown equipotential plots for ##C=1, \frac{3}{2},2##. Positive values in blue, negative values in red. Note that there is no separation between equipotentials at the origin as expected for a pure point dipole.
Likes BvU, vcsharp2003, vanhees71 and 1 other person
kuruman said:
The point dipole potential in polar coordinates shown in post #12 is easier to handle. It is an approximation in the limit r=x2+y2>>a, i.e. for distances much larger than the separation between charges.
I used to think that a point dipole is one in which the positions of +q and
-q charges coincide like in non-polar dielectrics. But, it seems, I was wrong.
It's just a model for finding the electric potential of, for example, polarized atoms or molecules in which the positive charge density ##\rho_+## and the negative charge density ##\rho_-## come into play. The monopole term is $$Q=\int_V\left(\rho_+(r)+\rho_-(r)\right)dV$$ and is zero if the atom or molecule is neutral. The dipole term of the atom is the charge density weighted by the position of the charge, $$\vec{p}=\int_V\left[\rho_+ (r) +\rho_-(r)\right]~\vec{r}~dV =\int_V\rho_+(r)~\vec{r}~dV+ \int_V\rho_-(r)~\vec{r}~dV.$$ This term may or may not be zero depending on how the positive and negative charges are distributed within the atom or molecule. Notably, the water molecule has a dipole moment which can be considered a point dipole but the picture is not that of a positive and a negative point charge separated by some distance.
Likes vcsharp2003
FAQ: Equipotential surfaces for an electric dipole
What are equipotential surfaces for an electric dipole?
Equipotential surfaces for an electric dipole are imaginary surfaces in space where the electric potential due to the dipole is constant. This means that any point on a given equipotential surface has the same electric potential. For an electric dipole, these surfaces are not spherical but rather take on more complex shapes, often resembling a series of nested, distorted spheres.
How are equipotential surfaces for an electric dipole different from those of a single point charge?
For a single point charge, equipotential surfaces are concentric spheres centered around the charge. In contrast, for an electric dipole, the equipotential surfaces are more complex due to the presence of both a positive and a negative charge. These surfaces are not symmetrical and are influenced by the positions and magnitudes of the two charges, leading to a more intricate pattern of surfaces.
How can equipotential surfaces for an electric dipole be visualized?
Equipotential surfaces for an electric dipole can be visualized using graphical methods or computer simulations. By plotting the electric potential at various points in space and connecting points with the same potential, one can create a 3D representation of the equipotential surfaces. These visualizations often show a series of lobes and saddle points, reflecting the complex nature of the dipole's electric field.
What is the relationship between equipotential surfaces and electric field lines for a dipole?
Equipotential surfaces and electric field lines are orthogonal to each other. For an electric dipole, the electric field lines emanate from the positive charge and terminate at the negative charge. These lines intersect the equipotential surfaces at right angles. This orthogonal relationship helps in understanding how the electric field behaves in the vicinity of the dipole and how the potential changes in space.
Why are equipotential surfaces important in understanding the behavior of electric dipoles?
Equipotential surfaces are important because they provide insight into the spatial distribution of electric potential around a dipole. Understanding these surfaces helps in analyzing how the dipole interacts with other charges and fields, and is crucial for applications in electrostatics, such as designing capacitors, understanding molecular dipoles, and in various fields of physics and engineering where electric dipoles play a role.
