mjordan2nd
- 177
- 1
Two infinitely long wires running parallel to the x-axis carry uniform charge densities [tex] \lambda [/tex] and [tex] - \lambda[/tex].
a.) Find the potential at any point (x, y, z) using the origin as your reference.
b.) Show the equipotential surfaces are circular cylinders, and locate the axis and radius of the cylinder corresponding to a given potential V_0.
In part a I oriented my axes such that both wires lay in the x-y plane a distance, a, away from the x-axis. I found the potential to be
[tex] V(x,y,z) = \frac{\lambda}{4 \pi \epsilon_{0}} ln \left[ \frac{(y-a)^{2}+z^{2}}{(y+a)^{2}+z^{2}} \right][/tex]
I know that I can find the equipotential surfaces by simply allowing the argument of the logarithm to be constant. I was wondering, however, if I could find the answer using partial derivatives as well. I feel that I should be able to find the equipotential surfaces to this potential by allowing the partial derivative with respect to y go to 0, and the partial derivative with respect to z go to 0. When both partials are 0, shouldn't I find an equipotential surface? I worked out the math, and my answer is inconsistent, so I believe that this method is incorrect, but I can't quite figure out why. If someone could point out the error in my logic, I would appreciate it. Thanks.
