Equivalence factor or n factor (Equivalent weight)
In summary, the equivalence factor of the salt FeSO4.Cr2(SO4)3.24H2O is 8, which represents its basicity or acidity and the number of electrons exchanged per mole of compound in a redox reaction. However, there may be confusion surrounding this value due to the possibility of multiple reactions taking place.
erisedk
374
Equivalence factor of the salt is FeSO4.Cr2(SO4)3.24H2O is
Ans is 8.
Equivalence factor of an acid or base is its basicity or acidity, and for a compound undergoing redox reaction, it is the number of electrons exchanged per mole of compound. I'm not sure how to go about in the case of the given salt.
Rather lousy question if you ask me. You can get 8 trying to precipitate hydroxides of both metals, but if you go for redox the more reasonable number is 7 (two Cr(III) get oxidized to Cr(VI) giving away 6 electrons, and Fe(II) gets oxidized to Fe(III) giving one electron, 6+1=7).
In general, equivalents are often confusing when there is more than one reaction that can take place (which is why they should be avoided in the initial chemistry lessons).
Likes epenguin
Ok thanks!
Related to Equivalence factor or n factor (Equivalent weight)
What is the definition of equivalence factor or n factor?
Equivalence factor or n factor is a concept in chemistry that is used to express the relative amount of a substance that participates in a chemical reaction. It is defined as the number of moles of a substance that reacts with or is equivalent to 1 mole of another substance.
How is the equivalence factor or n factor related to the concept of equivalent weight?
The equivalence factor or n factor is directly related to the concept of equivalent weight. Equivalent weight is the mass of a substance that reacts with or is equivalent to 1 mole of another substance. The equivalence factor or n factor is the ratio of the equivalent weight of a substance to the molar mass of that substance.
What factors determine the equivalence factor or n factor of a substance?
The equivalence factor or n factor of a substance is determined by the number of reactive species or ions present in a chemical reaction. For example, a monoprotic acid will have an equivalence factor or n factor of 1, while a diprotic acid will have an equivalence factor or n factor of 2.
What is the significance of equivalence factor or n factor in stoichiometric calculations?
The equivalence factor or n factor is crucial in stoichiometric calculations as it helps to determine the amount of substances needed for a chemical reaction. It is used to convert between different units, such as moles and mass, and to balance chemical equations.
How is the equivalence factor or n factor used in titration experiments?
In titration experiments, the equivalence factor or n factor is used to calculate the concentration of a substance being titrated. It is also used to determine the volume of a titrant needed to reach the equivalence point, where the moles of the titrant are equal to the moles of the substance being titrated.
