Equivalence of various forms of flux linkage
In summary, Chang writes that flux linkage is equivalent to the formulas for flux linkage that he found on the internet, which are based on the partial current I_enclosed/I_total.
lagrangman
Hello all,
Apologies if this has already been asked before, but I tried researching this question for a while with no results.
I was reading Grainger's Power System Analysis' derivation of the inductance of a single wire and got confused by his definition of magnetic flux linkage.
He seems to state that magnetic flux linkage (λ) is ∫ I dΦ where dΦ is a differential increase in magnetic flux and I is the incremental current that causes the differential increase in magnetic flux.
I am familiar with the following definitions of flux linkage (λ):
(1) λ = N Φ where Φ is the flux that N turns of conductor "contain."
(2) λ = ∫ V dt where V is voltage caused by electromagnetic induction and t is time.
(3) λ = L I where L is the inductance of an inductor-like device and I is the current flowing through the inductor-like device.
My question is why is ∫ I dΦ equivalent anyone of the three expressions above?
Thanks in advance!
If the flux is constant and you have N turns you get (1).
Thanks for the response, however I am still confused. Where does the contributing current factor in then?
Hopefully this isn't a copyright violation, but Chang writes, "the flux linkages dλ per meter of length, which are caused by the flux in the tubular element, are the product of the flux per meter of length and the fraction of the current linked." (p. 132.)
This would correspond to a formula for flux linkage I found on the internet (∫ I dΦ as defined above), but I don't know how to derive it from the other definitions of magnetic flux.
I might be making some mistakes so feel free to correct me.
Thanks again.
Could you please provide the web link ?
I really can't think of why flux linkage is equal to ∫ I dΦ .
I got it from here: https://www.physicsforums.com/threads/flux-linkage-in-inductance-calculation-for-single-wire.819129/
Sorry about the red herring and thank you for your time, but I think I figured it out. When people say fraction of current in this context, they mean I_enclosed/I_total. I thought fraction of current meant I_enclosed. So:
λ = ∫ f dΦ, where f is the partial current that causes the differential flux dΦ divided by the total current. I think, but am not positive, this equation is correct.
I had never seen this before so I was a little confused.
Thanks again!
Related to Equivalence of various forms of flux linkage
1. What is the concept of equivalence of various forms of flux linkage?
The concept of equivalence of various forms of flux linkage refers to the fact that different physical quantities, such as magnetic flux, electric current, and voltage, can be related to each other through mathematical equations. This allows us to understand and analyze the behavior of electromagnetic systems.
2. How is flux linkage defined?
Flux linkage is defined as the product of the magnetic flux and the number of turns in a coil. It represents the total amount of magnetic flux that passes through a given area and is linked to a particular circuit or coil.
3. What are the different forms of flux linkage?
The different forms of flux linkage include magnetic flux linkage, electric flux linkage, and self-inductance. Magnetic flux linkage is related to the amount of magnetic flux passing through a coil, while electric flux linkage is related to the amount of electric flux passing through a capacitor. Self-inductance is a measure of the ability of a circuit to generate an electromotive force (EMF) in response to a changing current.
4. How are the different forms of flux linkage related to each other?
The different forms of flux linkage are related through mathematical equations, such as Faraday's law of induction and Ohm's law. These equations allow us to convert between different forms of flux linkage and understand the interactions between different physical quantities in electromagnetic systems.
5. Why is the concept of equivalence of various forms of flux linkage important?
The concept of equivalence of various forms of flux linkage is important because it allows us to analyze and design complex electromagnetic systems, such as electric motors and generators. It also helps us to understand the relationship between different physical quantities and how they affect the behavior of these systems.
  • Electrical Engineering
11K
  • Electromagnetism
23K
