Equivalence relation and different sample spaces
In summary: This is the theorem you are talking about. It states that two propositions imply each other if the outcome of applying one to the other is always the same. In summary, the theorem states that if two propositions imply each other, then the probability of the two propositions is the same.
gregthenovelist
TL;DR Summary
Equivalence Relation fails when two propositions are not in the same sample space. Why?
It is a theorem that: two propositions implying each other, in the sense that the set of outcomes making one true is the same as the one making the other true) have the same probability. this comes from the fact that if p --> q, the P(p&q) = P(p), we have that if p <-> q, then P(p&q) = P(p)= P(q). but this is only so if p and q dwell in one sample space.
Question: what is the problem when they are not in the same sample space?
gregthenovelist said:
Summary:: Equivalence Relation fails when two propositions are not in the same sample space. Why?
How could this even hold if they are in different sample spaces? Do you have an example?
More generally, you always need an implied or explicit universal set. For example, consider the non-negative integers ##\{0, 1, 2 \dots \}## and the non-positive integers ##\{\dots -2, -1, 0 \}##. It only makes sense to form the intersection or union of these sets if we take the integers (or rationals or reals) as our universal set, of which both are subsets.
Likes gregthenovelist
This is exactly my question. why can we not even ask this question if they are in different sample spaces?
Because you cannot compare things that are different by nature. How would you define reflexivity or symmetry?
Great, that helps a lot. So, if we cannot combine them into a universal set (in this case rationals or reals), we cannot get an intersection. Thus, the equivalence principle would fail as it is in logical terms the same as the union of the two sets. Is my reasoning correct here?
great, makes sense!
It's just the same technical point that your overall or universal sample space must include all events. Implicitly or explicity, both sample spaces must be subsets of an overall universal sample space under consideration.
great, thanks! How exactly is reflexivity and symmetry important for the equivalence relation?
An equivalence relation ##\sim## is defined to be
a) reflexive ##a\sim a##,
b) symmetric ##a\sim b \Longrightarrow b\sim a## and
c) transitive ##a\sim b \wedge b\sim c \Longrightarrow a\sim c##
This is its definition.
What theorem are you talking about?
In the first place we should distinguish between a proposition versus a propositional function. In the usual terminology, a proposition is a statement that is either true or false and not both. For example, in mathematics, ##2 < 5## is a proposition. A propositional function is a function that maps some set of things into the set ##\{True, False\}##. For example, ##x < 5## is a propositional function.
So if you want to talk about a logical function whose domain is a set of outcomes, then you should talk about a propositional function. This brings up the question of what it means for one propositional function to imply another propositional function.
Presumably, we interpret that like ##\forall x ( P(x) \implies Q(x) )##. Even before we introduce the idea of probability, we have to decide if that interpretation implies that ##P## and ##Q## are functions with the same domain.
FAQ: Equivalence relation and different sample spaces
What is an equivalence relation?
An equivalence relation is a mathematical concept that defines a relationship between elements of a set. It states that two elements are considered equivalent if they share certain properties or characteristics.
How is an equivalence relation different from an equality relation?
An equivalence relation is a more generalized concept than an equality relation. While an equality relation only considers two elements to be equivalent if they are exactly the same, an equivalence relation allows for elements to be equivalent based on shared properties or characteristics.
What is the importance of equivalence relations in mathematics?
Equivalence relations are important in mathematics because they allow for the classification and organization of elements within a set. They also provide a way to compare and analyze different objects or concepts based on shared properties.
How are equivalence relations used in different sample spaces?
In different sample spaces, equivalence relations can be used to group elements or outcomes together based on shared properties or characteristics. This allows for a better understanding and analysis of the sample space as a whole.
Can you give an example of an equivalence relation in everyday life?
One example of an equivalence relation in everyday life is the concept of "equality" in social and political contexts. While individuals may have different backgrounds, beliefs, or identities, they are considered equal if they share certain fundamental rights and protections.
