MHB Equivalence relation-equivalence classes
The discussion centers on proving that the relation \( I_E = \{<x,x> : x \in E\} \) is a set and an equivalence relation on the set \( E = \{d,e,f\} \). Participants clarify that \( I_E \) is reflexive, symmetric, and transitive, confirming it as an equivalence relation. They explore the equivalence classes, concluding that each element in \( E \) is only equivalent to itself, resulting in the classes \( [d] = \{d\} \), \( [e] = \{e\} \), and \( [f] = \{f\} \). The discussion emphasizes the need for precise definitions and understanding of reflexivity and the nature of equivalence classes.
evinda
MHB
Hello! (Smile)
We are given the set $E=\{d,e,f \}$, $d,e,f$ different from each other and the relation $I_{E}=\{ <x,x>: x \in E\}$. Prove that $I_{E}$ is a set. In addition, show that the relation $I_{E}$ is an equivalence relation in $E$ and find all the equivalence classes.
That's what I have tried:
We define $\phi(x)=<x,x>: x \in E$.
Then, we have that $\forall <x,x>(\phi(x)) \rightarrow <x,x> \in E \times E$.
$E \times E$ is a set.
So, from the theorem: "Let $\phi$ a type. If there is a set $Y$, such that $\forall x(\phi(x)) \rightarrow x \in Y$, then there is the set $\{ x: \phi(x) \}$", we have that $I_{E}=\{ <x,x>: x \in E\}$ is a set.
The relation $I_{E}$ is an equivalence relation:
  • reflective: $<x,x> \in I_{E} \rightarrow <x,x> \in I_{E}$
  • symmetric: $<x,y> \in I_{E} \rightarrow x=y \rightarrow <y,x> \in I_{E}$
  • transitive: $<x,y> \in I_{E} \wedge <y,z> \in I_{E} \rightarrow x=y \wedge y=z \rightarrow <x,z> \in I_{E}$
Is it right so far? How could we find all the equivalence classes? (Thinking)
It is not clear what this means. $\phi(x)$ must be a property, i.e., something that is either true or false for every $x$. How is what you wrote true or false for a given $x$?
Recall that the notation $\{\langle x,x\rangle:x\in E\}$ is a contraction for $\{y:\exists x\in E\;y=\langle x,x\rangle\}$. Then it make sense to define $\phi(y)$ to be $\exists x\in E\;y=\langle x,x\rangle$. Then $\phi(y)$ is indeed true or false for every $y$. Next, we indeed have that $\forall y\;(\phi(y)\to y\in E\times E)$, and since $E\times E$ is a set, $\{y:\phi(y)\}$ is also a set.
Symmetry and transitivity make sense, but the definition of reflexivity does not involve an implication.
The equivalence class of $d$ consists of all elements that are equivalent to $d$ with respect to this relation. What are those elements?
I understand.. (Nod) Do we have to prove that $E \times E$ is a set? If so, how could we do this? (Thinking)
So, can we just say that it is obvious that the relation is reflective? (Thinking)
Do these elements belong maybe to this set: $\{ \langle x,y \rangle : x,y \in E \}=\{ \langle x,y \rangle: x=y \wedge x \in E\}=\{ \langle x,x \rangle: x \in E\}=\bigcup \{ \langle x,x \rangle: x \in E\} $
Or am I wrong? (Worried)
You proved in another thread that the Cartesian product of two sets is a set.
You write that something is obvious if, first, you personally are able to explain this fact at any level of detail, up to axioms, and, second, you think that it is clear to the reader as well. It's hard for me to say if you can explain this fact at any level of detail.
You have three elements: $d$, $e$ and $f$. What is equivalent to $d$, i.e., what is related to $d$ by the relation $I_E$? Well, $e$ is not because $\langle d,e\rangle\notin I_E$. Is $f$ equivalent to $d$? Is $d$? Those elements for which the answer is yes form the equivalence class of $d$, often denoted by $[d]$. Do the same thing with $e$ and $f$.
So, since we know that the Cartesian product of two sets is a set, can we just say that $E \times E$ is a set, as it is a Cartesian product? (Thinking)
Isn't a relation $R$ reflective, if $xRx$ ? In our case, it is always $xI_{E}x$, or am I wrong? :confused:
The only element that is equivalent to $d$ is $d$, right?
So, is it like that?
$$[d]=d, \ [e]=e \ , [f]=f$$
Or am I wrong? (Thinking)
Yes.
Correct, but the equivalence class is a set because in general it consists of several elements, so the right-hand sides should be surrounded by curly braces.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
