Equivalence Relations: Explaining $I_A$, $\rho^{-1}$ and $\rho \circ \rho$
In summary, the three conditions presented (namely, $I_A \subset \rho$, $\rho^{-1}=\rho$, and $\rho \circ \rho \subset \rho$) correspond to the properties of reflexivity, symmetry, and transitivity, respectively. It is recommended to take concrete examples to determine whether these properties hold or not, in order to build intuition. For instance, the relation $\rho$ defined as $m\mathrel{\rho}n\iff m\le n$ on natural numbers shows that $\rho^{-1}$ is not a subset of $\rho$, meaning that $\rho$ is not symmetric. However, $\rho^{-1}\subseteq\rho$ is equivalent to $\rho^{-1}
evinda
MHB
3,836
Hi again! (Smile)
If $\rho$ is an equivalence relation, could you explain me why the following relations stand? (Thinking)
  • $I_A \subset \rho$
  • $\rho^{-1}=\rho$
  • $\rho \circ \rho \subset \rho$
These three conditions correspond to reflexivity, symmetry and transitivity, respectively. Again, I would recommend taking some concrete relations (ideally, those where these properties hold and where they don't) and determine whether the properties you listed hold. This will help build intuition.
For example, let $m\mathrel{\rho}n\iff m\le n$ on natural numbers. Then $\langle 3,5\rangle\in\rho$, but $\rho^{-1}\ni\langle 5,3\rangle\notin\rho$; therefore, $\rho^{-1}\not\subseteq\rho$. The same fact is expressed by saying that $3\le 5$, but $5\not\le 3$. Both these statements mean that $\rho$ is not symmetric. Note, by the way, that $\rho^{-1}\subseteq\rho$ is equivalent to $\rho^{-1}=\rho$ for any $\rho$ because $\rho^{-1}\subseteq\rho$ implies that $(\rho^{-1})^{-1}\subseteq\rho^{-1}$, i.e., $\rho\subseteq\rho^{-1}$.
FAQ: Equivalence Relations: Explaining $I_A$, $\rho^{-1}$ and $\rho \circ \rho$
What is an equivalence relation?
An equivalence relation is a mathematical concept that defines a relationship between elements of a set. It is a binary relation that satisfies three properties: reflexivity, symmetry, and transitivity.
What is the purpose of $I_A$ in equivalence relations?
$I_A$ is the identity relation on set A, which means that for every element in the set, it is related to itself. This is an important concept in equivalence relations because it ensures that the reflexivity property is satisfied.
How does the function $\rho^{-1}$ relate to equivalence relations?
The function $\rho^{-1}$ is the inverse relation of $\rho$, which means that for every element (x,y) in $\rho$, there is an element (y,x) in $\rho^{-1}$. This is important in equivalence relations because it ensures that the symmetry property is satisfied.
What is the significance of composing two equivalence relations, $\rho \circ \rho$?
Composing two equivalence relations means that the resulting relation contains elements that are related in both $\rho$ and $\rho$. This ensures that the transitivity property is satisfied, and the resulting relation is still an equivalence relation.
How are equivalence relations used in mathematics and other fields?
Equivalence relations are used in various areas of mathematics, including algebra, geometry, and logic. They are also used in other fields, such as computer science, linguistics, and sociology, to model and understand relationships between objects or concepts.
