Parallely Connect Batteries: What is the Equivalent Emf?
In summary: The first part - Cells produce current by converting chemical energy into electrical energy . The reaction in cells involves movement of ions , and th e resistance offered inside the cell , to their movement is the internal resistance .When electrons move through the circuit , there is an exchange of energy . This is where the term "equivalent emf" comes from.When two cells are connected in parallel, the current flow is infinite. However, if the cells have large enough internal resistance, the cells can be connected. Additionally, if the internal resistance is negligible, the current will be the same as if the cells were not connected. However, if the cells have the same internal resistance, the current flow will be different depending on the relative
fireflies
210
I heard that, emf cannot be parallely connected provided that the value of the emf are not same.
Is this correct? Like, what would happen when batteries with 3V, 4V, 5V are parallely connected? And the equivalent emf?
Well , yes . Imagine two cells connected to each other . If conditions are perfectly ideal , then current in that loop would be infinite ( From Kirchoff's loop law ) .
However , if they both have large enough internal resistance , then you could connect them ( Why ? ) .
And the third case - If internal resistance tends to negligible , similar to the first case , current would ...
The 5V battery would discharge through the lower voltage batteries. The resultant emf is going to depend on the relative resistances of the batteries. Also, the current that flows will depend on the resistances. Some batteries will be seriously harmed by such an arrangement.
If there was some good reason for hooking these in parallel (I can't think of a good one off hand, but there might be) you might be able to get somewhere by putting in a diode at the correct locations.
Likes fireflies
The two cells connected in which way? Just connected? Or, with an external resistance also?
Either way , doesn't matter . Consider the loop containing both the cells only . It doesn't matter what the external resistance is .
Well, it will harm the other batteries, but will be of some work for itself, right?
Then the similar case would happen with a cell connected with a single wire(short circuit). The current flow will be infinity.
But does it actually happen?
(Sorry, I was troubling in posting messages, so I rewrote it)
I think you should first state what conditions you are assuming .
Well, I have lackings in this. Does the internal resistance include the resistance of the wire?
I don't know what you meant by conditions. I'm just talking about a normal cell, where two ends of the emf are short-circuit. So, then also, the current flow will be infinity, right? (From the thought you said for the two connected cells).
What I am trying to say, is that, if the cells connected in parallel faces infinity current, so does the short-circuit (I knew it doesn't??). So, what makes parallel cells more impossible?
I understand the fact that the cells will be damaged, and it is impractical to do so. But what happens, if connected? What about the equivalent emf?
When electrons move through the circuit , there is an opposition to their flow . This constitutes the resistance of the wire ( It is considered negligible in many cases ) .
You seem to be mixing the concepts of ideal circuits to real ones . A circuit with enough resistance can have , say , batteries of 5V and 4V connected in parallel .
But what if they don't have enough resistance?
See post #2 , or #3 .
That means, only the 5V battery is going to work?
What equivalent emf? Suppose, if the internal resistance be 1 ohm, for two cells 5V and 4V parallely connected? The question may seem silly, but is popping in my head.
It's a straightforward circuit to sketch. You need to represent each of these non-ideal components by something equivalent but comprising all ideal elements, then apply circuit theory such as Ohms Law.
First step: sketch the equivalent circuit, and post your sketch here.
Related to Parallely Connect Batteries: What is the Equivalent Emf?
What is the concept of parallely connecting batteries?
Parallely connecting batteries refers to the process of connecting two or more batteries together in a circuit so that their positive terminals are connected to each other and their negative terminals are connected to each other. This results in an increase in the total current output of the batteries, allowing for longer lasting power.
What is the equivalent EMF in parallely connected batteries?
The equivalent EMF (Electromotive Force) in parallely connected batteries is the total voltage output of all the batteries combined in the circuit. This value is calculated by adding the individual EMF values of each battery together.
How does parallely connecting batteries affect the overall circuit?
Parallely connecting batteries can increase the overall current output of the circuit, which can in turn affect the brightness of light bulbs or the power of electronic devices. It can also increase the lifespan of the batteries as they are sharing the load and not being drained as quickly.
What are some potential risks of parallely connecting batteries?
One potential risk of parallely connecting batteries is that if one battery has a significantly lower voltage output than the others, it can cause an imbalance in the circuit and potentially damage the batteries. It is important to use batteries with similar voltages when connecting them in parallel.
What are some real-life applications of parallely connected batteries?
Parallely connected batteries are commonly used in electronic devices such as laptops, smartphones, and flashlights. They are also used in backup power systems, such as uninterruptible power supplies (UPS), to provide a continuous power supply in case of a power outage.
  • Other Physics Topics
  • Electromagnetism
