Equivalent resistance & current
In summary, the question involves finding the value of R1 in a loop circuit with a resistance of R1 and a current of 3A, which is reduced to 1.6A when an additional resistor of 2ohms is added in series. By setting the equations for voltage equal to each other, R1 can be solved for and has a value of approximately 2.285 ohms. There was a small algebraic error in the calculation, but the final answer is correct.
pattiecake
64
ok, so the problem states: the current in a loop circuit that has a resistance of R1 is 3A. The current is reduced to 1.6A when an additional resistor R2=2ohms is added in series with R1. What is the value of R1?
I drew two diagrams. My logic was that the voltage would be the same, b/c the voltage is supplied by the battery which does not change. Thus you have V=I1R1 for the first scenario; and you have V=I2(R1+R2). Since V is the same, you can set the two equations equal to each other, and solve for R1.
Is the logic right so far? If so, maybe I just have an algebratic error...
(3A)R1=(1.6A)(R1+2ohms)
(3/1.6)=(R+2)/R
1.875=1+R/2
.875=R/2
R=1.75 ohms?
That is almost correct, you made a mistake here:
[tex]\frac{3}{1.6} = \frac{R+2}{R}[/tex]
Needs to become:
[tex]1.875 = 1 + \frac{2}{R}[/tex]
I get R1 = 2.285 from breaking that down 2 different ways.
[tex](3)(R_1) = (1.6)(R_1 + 2)[/tex]
[tex]3R_1 = 1.6R_1 + 3.2[/tex]
[tex]1.4R_1 = 3.2[/tex]
[tex]R_1 = 2.285[/tex]
[tex]\frac{3}{1.6} = \frac{R_1 + 2}{R_1}[/tex]
[tex]1.875 = 1 + \frac{2}{R_1}[/tex]
[tex]0.875 = \frac{2}{R_1}[/tex]
[tex]R_1 = \frac{2}{0.875}[/tex]
thank you! thank you! thank you!
FAQ: Equivalent resistance & current
What is equivalent resistance?
Equivalent resistance refers to the single resistance value of a circuit that would produce the same amount of current flow as the original circuit. It is calculated by combining individual resistances in series or parallel.
How do you calculate equivalent resistance?
The formula for calculating equivalent resistance in a series circuit is R = R1 + R2 + R3 + ..., where R represents the equivalent resistance and R1, R2, R3, etc. represent the individual resistances. In a parallel circuit, the formula is 1/R = 1/R1 + 1/R2 + 1/R3 + ..., and the equivalent resistance is then calculated by taking the reciprocal of the sum.
What is the relationship between equivalent resistance and current?
The equivalent resistance of a circuit determines the amount of current that will flow through it. If the equivalent resistance is low, the current will be high, and vice versa. This relationship is known as Ohm's Law, which states that current is directly proportional to voltage and inversely proportional to resistance.
How does adding resistors in series or parallel affect equivalent resistance?
Adding resistors in series increases the equivalent resistance, as the total resistance is the sum of individual resistances. On the other hand, adding resistors in parallel decreases the equivalent resistance, as the total resistance is calculated by taking the reciprocal of the sum of individual resistances.
Can the equivalent resistance of a circuit ever be lower than the lowest individual resistance?
No, the equivalent resistance of a circuit can never be lower than the lowest individual resistance. This is because adding resistors in parallel will always result in a lower resistance, but the equivalent resistance can never be lower than the lowest individual resistance in the circuit.
