MHB Erin's question via email about a Fourier Transform
The discussion focuses on finding the Fourier Transform of a piecewise function defined for specific intervals. The calculation involves integrating the function over its defined ranges and applying integration techniques to derive the final expression. The resulting Fourier Transform is expressed as F(ω) = (1 - cos(2ω))/ω², highlighting its dependence on the frequency variable ω. Additionally, a comment suggests that understanding Fourier transforms can be enhanced through distribution theory, referencing a specific book for further reading. The conversation emphasizes both the mathematical process and theoretical insights related to Fourier analysis.
Prove It
MHB
Find the Fourier Transform of $\displaystyle \begin{align*} f \left( t \right) = \begin{cases} 1 - \frac{t}{2} \textrm{ if } 0 \leq t \leq 2 \\ 1 + \frac{t}{2} \textrm{ if } -2 \leq t < 0 \\ 0 \textrm{ elsewhere } \end{cases} \end{align*}$
$\displaystyle \begin{align*} F \left( \omega \right) &= \mathcal{F} \left\{ f \left( t \right) \right\} \\
&= \int_{-\infty}^{\infty}{ f\left( t \right) \mathrm{e}^{-\mathrm{j}\,\omega \, t}\,\mathrm{d}t } \\
&= \int_{-\infty}^{-2}{ 0\,\mathrm{d}t } + \int_{-2}^0{ \left( 1 + \frac{t}{2} \right) \mathrm{e}^{-\mathrm{j}\,\omega\,t}\,\mathrm{d}t } + \int_0^2{ \left( 1 - \frac{t}{2} \right) \mathrm{e}^{-\mathrm{j}\,\omega\,t}\,\mathrm{d}t } + \int_2^{\infty}{0\,\mathrm{d}t} \\
&= 0 + \left[ \left( 1 + \frac{t}{2} \right) \left( \frac{\mathrm{e}^{-\mathrm{j}\,\omega\,t}}{-j\,\omega} \right) \right]_{-2}^0 - \int_{-2}^0{ \frac{\mathrm{e}^{-\mathrm{j}\,\omega\,t}}{-2\,\mathrm{j}\,\omega}\,\mathrm{d}t } + \left[ \left( 1 - \frac{t}{2} \right) \left( \frac{\mathrm{e}^{-\mathrm{j}\,\omega\,t}}{-\mathrm{j}\,\omega} \right) \right]_0^2 - \int_0^2{ \frac{\mathrm{e}^{-\mathrm{j}\,\omega\,t}}{2\,\mathrm{j}\,\omega}\,\mathrm{d}t } + 0 \\
&= \frac{1}{-\mathrm{j}\,\omega} - \left[ \frac{\mathrm{e}^{-\mathrm{j}\,\omega\,t}}{2\,\mathrm{j}^2\,\omega^2} \right] _{-2}^0 - \left( \frac{1}{-\mathrm{j}\,\omega} \right) - \left[ \frac{\mathrm{e}^{-\mathrm{j}\,\omega\,t}}{-2\,\mathrm{j}^2\,\omega^2} \right] _0^2 \\
&= \left[ \frac{\mathrm{e}^{-\mathrm{j}\,\omega\,t}}{2\,\omega^2} \right] _{-2}^0 - \left[ \frac{\mathrm{e}^{-\mathrm{j}\,\omega\,t}}{2\,\omega^2} \right] _0^2 \\ &= \frac{1}{2\,\omega^2} \left\{ \left[ \mathrm{e}^{-\mathrm{j}\,\omega\,t } \right] _{-2}^0 - \left[ \mathrm{e}^{-\mathrm{j}\,\omega\,t} \right] _0^2 \right\} \\
&= \frac{1}{2\,\omega^2} \left[ \left( 1 - \mathrm{e}^{2\,\mathrm{j}\,\omega } \right) - \left( \mathrm{e}^{-2\,\mathrm{j}\,\omega\,t} - 1 \right) \right] \\ &= \frac{1}{2\,\omega^2} \left[ 2 - \left( \mathrm{e}^{2\,\mathrm{j}\,\omega} + \mathrm{e}^{-2\,\mathrm{j}\,\omega} \right) \right] \\ &= \frac{1}{\omega^2} \left[ 1 - \left( \frac{\mathrm{e}^{2\,\mathrm{j}\,\omega} + \mathrm{e}^{-2\,\mathrm{j}\,\omega}}{2} \right) \right] \\ &= \frac{1 - \cos{ \left( 2\,\omega \right) }}{\omega ^2} \end{align*}$
Mathematics news on Phys.org
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
