Ernesto's question at Yahoo Answers regarding finding a locus of points
  • MHB
  • Thread starter MarkFL
  • Tags
    Points
In summary: Hence, the locus of points is a circle of radius $\dfrac{\sqrt{145}}{4}$ centered at the origin. In summary, the sum of the lengths of the tangents from a point P to two circles is a constant value of 5, and the locus of the point P is a circle of radius $\dfrac{\sqrt{145}}{4}$ centered at the origin.
MarkFL
MHB
13,288
Here is the question:
The sum of the lengths of the tangents from a point P to the circumferences...?
The sum of the lengths of the tangents from a point P to the circumferences:
C1 : x² + y² = 4
and
C2 : x² + y² = 9
is constant and equal to 5.
Determine the locus of the point P.
Explain.
Thanks.
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Ernesto,
Let's orient a circle or radius $r$ centered at the origin, and place a point on the $x$-axis outside of the circle, and let it's distance from the origin be $d$. Drawing a tangent line from this point to the circle (in the first quadrant), we form a right triangle, since the tangent line is perpendicular to the radius of the circle drawn to the tangent point. Let $\ell$ be the length of this line segment. Hence, we may state:
\(\displaystyle r^2+\ell^2=d^2\)
Solving for $\ell$, we obtain:
\(\displaystyle \ell=\sqrt{d^2-r^2}\)
Now, observing that there is also a fourth quadrant tangent point, we may state that the sum $S$ of the lengths of the tangent line segments is:
\(\displaystyle S=2\sqrt{d^2-r^2}\)
Now, if we do this for two circles, one of radius $r_1$ and the other of radius $r_2$, we then have:
\(\displaystyle S=2\left(\sqrt{d^2-r_1^2}+\sqrt{d^2-r_2^2} \right)\)
In order to ease solving for $d$, let's write the equation as:
\(\displaystyle S-2\sqrt{d^2-r_2^2}=2\sqrt{d^2-r_1^2}\)
Squaring both sides of the equation, there results:
\(\displaystyle S^2-4S\sqrt{d^2-r_2^2}+4\left(d^2-r_2^2 \right)=4\left(d^2-r_1^2 \right)\)
Distributing and combining like terms, and isolating the term with the remaining radical we obtain:
\(\displaystyle 4S\sqrt{d^2-r_2^2}=4r_1^2-4r_2^2+S^2\)
Squaring again, we obtain:
\(\displaystyle 16S^2\left(d^2-r_2^2 \right)=\left(4r_1^2-4r_2^2+S^2 \right)^2\)
\(\displaystyle d^2=\frac{\left(4r_1^2-4r_2^2+S^2 \right)^2}{16S^2}+r_2^2=\frac{\left(4\left(r_1^2-r_2^2 \right)+S^2 \right)^2+\left(4r_2S \right)^2}{(4S)^2}\)
Now, since this will hold for any point that is a distance $d$ from the origin, which describes a circle centered at the origin having radius $d$, we then find the locus of points is:
\(\displaystyle x^2+y^2=\frac{\left(4\left(r_1^2-r_2^2 \right)+S^2 \right)^2+\left(4r_2S \right)^2}{(4S)^2}\)
Now, using the data given with the problem:
\(\displaystyle r_1=2,\,r_2=3,\,S=5\)
We find the locus of points is:
\(\displaystyle x^2+y^2=\left(\frac{\sqrt{145}}{4} \right)^2\)
FAQ: Ernesto's question at Yahoo Answers regarding finding a locus of points
What is a locus of points?
A locus of points is a set of points that satisfy a given condition or set of conditions. It can be thought of as a path or route that all the points must follow.
How do you find the locus of points?
To find the locus of points, you must first determine the condition that must be met by all the points. This condition can be represented by an equation or set of equations. Then, you can manipulate the equation(s) to represent the points in terms of one or more variables. The resulting equation will be the locus of points.
Why is finding the locus of points important?
Finding the locus of points can help to identify patterns or relationships between points that satisfy a given condition. This can be useful in various fields of study, such as mathematics, physics, and engineering. It can also help to solve problems or answer questions related to a specific set of points.
Can the locus of points be represented graphically?
Yes, the locus of points can be represented graphically on a coordinate plane. The points that satisfy the given condition will lie on the graph of the equation representing the locus. This can help to visualize the path or pattern of the points.
What are some common examples of locus of points?
Some common examples of locus of points include circles, parabolas, and ellipses. These shapes can be represented by equations that describe the set of points that make up the shape. Other examples can include paths of objects in motion, such as the orbit of a planet around the sun or the path of a projectile.
