freja
- 7
Hiya. I am able ot compile my program with no errors but when I run it I get the message:
Error 112, Reference to undefined variable, array element or function result.
I cannot see where I have gone wrong and more frustratingly this code was working, running producing results on the unix system at university but when I compile it on my windows system using silverfrost plato it gives this error. This is my code: (the line is bold is what it objects to)
PROGRAM project1
! MTMW14 Project 1: A Simplified Model of Ocean Gyres and the Gulf Stream
! Date Created: 27/01/2009 Author: Freja Hunt Version 1
! Simulate wind driven circulation in a closed basin with a western boundary current using the Stommel (1948) model
! and Arakawa C grid with a mixed explicit-implicit time scheme.
IMPLICIT NONE
! Define variables
REAL, PARAMETER:: fo=10.0**(-4), beta=10.0**(-11), g=10.0, drag=10.0**(-6), density=1000.0,&
& windo=0.2, tstep=100.0, pi=3.1415926535, L=10.0**(6)
! fo is the reference coriolis parameter, beta is the beta plane approximation that allows the coriolis parameter to vary with latitude,
! g is the accerleration due to gravity, drag is the linear drag coefficient, density is the density of sea water,
! windo is the reference wind stress, tstep is the time step (s), L is spatial extent of the basin
INTEGER, PARAMETER:: ntsteps=1, gridstep=10000, depth=1000, xlength=L/gridstep, ylength=L/gridstep
! ntsteps is the number of time steps to run for, gridstep is the distance between grid points, depth is the resting depth of the fluid
! xlenght and ylength are the number of grid points across the basin
REAL, DIMENSION(xlength,ylength):: u, unext, usqrd, v, vnext, vsqrd, surf, surfnext, surfsqrd, x, y
! u is the velocity in the x direction, v is the velocity in the y direction, surf is the surface elevation
! x is the distance east, y is the distance north
REAL:: energy, energytime(ntsteps) ! Energy is the total energy of the peturbation from the resting system
INTEGER:: i, j, n
! i is the x component, j is the y compentent, n is the time index
! Assign values to x and y arrays
x(1,:)=0
DO i=2, xlength
x(i,:)=x(i-1,:)+gridstep
END DO
y(:,1)=L
DO j=2, ylength
y(:,j)=y(:,j-1)-gridstep
END DO
! Assign initial values of zero to the surface elevation, u and v
DO j=1, ylength
DO i=1, xlength
surf(i,j)=0
u(i,j)=0
v(i,j)=0
END DO
END DO
! Set boundary conditions
v(1:xlength,1)=0 ! Set the northward velocity at the north boundary to zero, ie the first row is zero across all columns
v(1:xlength,ylength)=0 ! Set the northwards velocity to zero at the south boundary, ie the lasow is zero across all columns
u(1,1:ylength)=0 ! Set the eastwards velocity to zero at the west boundary, ie the first column is zero at all rows
u(xlength,1:ylength)=0 ! Set the eastwards velocity to zero at the east boundary,ie the last is zero across all rows
DO n = 1, ntsteps
DO j = 2, ylength-1
DO i = 2, xlength-1
IF (((n/2)*2)/=n) THEN ! Define the scheme for the odd times steps
surfnext(i,j)= surf(i,j) - depth*tstep*(((u(i+1,j)+u(i,j))/gridstep) + &
&((v(i,j+1)-v(i,j))/gridstep))
unext(i,j)= u(i,j) + (fo+beta*y(i,j))*tstep*v(i,j) - g*tstep* &
& ((surfnext(i,j) - surfnext(i-1,j))/gridstep) - drag*tstep*u(i,j) + &
& ((windo*(-cos((pi*y(i,j))/L))/(density*depth)))*tstep
vnext(i,j)= v(i,j) - (fo+beta*y(i,j))*tstep*unext(i,j) - &
& g*tstep*((surfnext(i,j) - surfnext(i,j-1))/gridstep) - drag*tstep*v(i,j)
ELSE ! Define the scheme for the even time steps
vnext(i,j)= v(i,j) - (fo+beta*y(i,j))*tstep*u(i,j) - &
unext(i,j)= u(i,j) + (fo+beta*y(i,j))*tstep*vnext(i,j) - g*tstep* &
END IF
! Switch arrays over for next step
surf=surfnext
u=unext
v=vnext
END DO
END DO
! Square variables to calculate the total energy at this time step
DO j=1, ylength
DO i=1, xlength
usqrd(i,j)=u(i,j)**2
vsqrd(i,j)=v(i,j)**2
surfsqrd(i,j)=surf(i,j)**2
END DO
END DO
! Calculate the total energy of the peturbation from rest
energy = 0.5*density*(depth*((sum(usqrd)) + (sum(vsqrd)))) + g*(sum(surfsqrd))
energytime(n)=energy ! Saves total energy into an array at each time step
END DO
! Write results to a file
OPEN(UNIT=55, FILE='project1_u.dat')
DO j=1, ylength
WRITE(55,*) u(:,j)
END DO
CLOSE(55)
OPEN(UNIT=56, FILE='project1_v.dat')
DO j=1, ylength
WRITE(56,*) v(:,j)
END DO
CLOSE(56)
OPEN(UNIT=57, FILE='project1_surf.dat')
DO j=1, ylength
WRITE(57,*) surf(:,j)
END DO
CLOSE(57)
OPEN(UNIT=58, FILE='project1_energy.dat')
DO n=1, ntsteps
WRITE(58,*) energytime(n)
END DO
CLOSE(58)
END PROGRAM project1
Any help REALLY apprechiated.
PROGRAM project1
IMPLICIT NONE
! Define variables
INTEGER:: i, j, n
x(1,:)=0
DO i=2, xlength
END DO
y(:,1)=L
DO j=2, ylength
END DO
DO j=1, ylength
DO i=1, xlength
surf(i,j)=0
u(i,j)=0
v(i,j)=0
END DO
END DO
DO n = 1, ntsteps
DO j = 2, ylength-1
DO i = 2, xlength-1
END IF
surf=surfnext
u=unext
v=vnext
END DO
END DO
DO j=1, ylength
DO i=1, xlength
END DO
END DO
END DO
DO j=1, ylength
WRITE(55,*) u(:,j)
END DO
CLOSE(55)
DO j=1, ylength
WRITE(56,*) v(:,j)
END DO
CLOSE(56)
DO j=1, ylength
END DO
CLOSE(57)
DO n=1, ntsteps
END DO
CLOSE(58)
