Error analysis: significant figues
In summary, significant figures indicate the level of accuracy in a measurement. When multiplying measurements, the result should have no more significant figures than the measurement with the fewest significant figures. In this case, the volume would be 10200cm3 with three significant figures. Terminal zeroes are only significant if noted, and it is important to round off to the lowest number of significant figures. Significant figures also indicate the precision and accuracy of a measurement.
armolinasf
196
I have three measurements for the L, W, H of a box: 40.4, 14.9, 17.0. the volume would then be 10233.32cm. each of my measurements has three sig figures, and it says in my book that with multiplication the product should have no more sig figures than the measurement with the fewest sig figures. So does this mean that my measurement would be 10200cm? thanks for the help
Exactly so.
If it helps, think of significant figures as your degree of accuracy in a question.
Edit: Just as a clarifying example,
If I want to multiply 4.8 m by 9.4854, my exact result will be 45.52992 m.
This result is extremely accurate. It's so precise that it takes into account all the units down to 20 micrometers.
But how could we know that it's the correct answer when your first measurement was only held 2 digits of information? Perhaps, if you measured closer, you would have found that it was 4.78923 m instead.
More precisely, it would be 10200 cm3.
I've seen some disagreement in texts about whether terminal zeroes are significant. It might be safer to write the answer as 1.02 x 104 cm3.
I was always taught that terminal zeroes are only significant if it is noted that they are significant (i.e 345000m six sig figs is completely different to 34500 3 sig figs) but yes as the others have stated, keep as many figures as you can until you reach the final answer and then round to the specified significant figure
I agree with these responses, you should round off to the lowest number of significant figures.
A good way, I find, to appreciate the meaning of significant figures is to realize what the number you write down is NOT telling you.
The length of your box is given as 40.4cm, this means it is NOT 40.3cm and it is NOT 40.5cm. This means you cannot calculate an answer with any knowledge of the number beyond 3 figures.
Significant figures are also closely related to the accuracy of measurement. If you quote a measurement to 3 significant figures it implies that the measurement was made to better than 1%. the 40.4cm measurement given implies that the measurement could be made to within +/- 0.1cm which is about 1/4%...very accurate
FAQ: Error analysis: significant figues
What is significant figures?
Significant figures are the digits in a number that are known with certainty. They are used to indicate the precision of a measurement or calculation.
Why is it important to consider significant figures in error analysis?
Significant figures are important in error analysis because they help to determine the accuracy and precision of a measurement or calculation. They also help to determine the amount of uncertainty in a result.
How do you determine the number of significant figures in a measurement?
The general rule for determining the number of significant figures in a measurement is to count all non-zero digits and any zeros between two non-zero digits. Zeros at the beginning of a number are not significant, but zeros at the end of a number may or may not be significant, depending on the measurement instrument and the context.
What is the difference between accuracy and precision?
Accuracy refers to how close a measurement or calculation is to the true or accepted value. Precision refers to the consistency and reproducibility of a measurement or calculation. A measurement can be precise but not accurate, or accurate but not precise.
How do you account for significant figures in error propagation?
In error propagation, significant figures are used to determine the number of digits that should be included in the final result. The general rule is to keep the same number of significant figures in the result as the measurement with the least number of significant figures. However, it is important to consider the rules for rounding and performing calculations with significant figures to ensure accuracy and precision.
