Error calculation for µ in standing wave experiment
In summary, the experimenter tried to calculate the absolute error of µ (linear mass per unit length) and was not able to do so. He used tabulated data from the experiment to find the tension, speed, and c^2 values, but was not able to calculate the absolute error. He then attempted to average the tensions and speeds, but this did not seem to make sense and he did not understand what he was doing. He estimates that the absolute error is 644.9*10^-6 kg/m.
rasalzari
27
I experimented with standing waves on an oscillating string, and I was asked to calculate the absolute error of µ (linear mass per unit length). I don't know how to calculate it, so please help me.
I loaded 100g, 200g and 300g on the string. Below are tabulated data of the experiment.
I know the basics of uncertainties, but in here it's kinda complicated as I don't know how to calculate the tension or speed error. I know this formula:
where c= speed, FT= tension and µ = linear mass per unit length
making µ the subject:
[/B]
So the calculated tension for the 3 sets of masses are:
100g = 9.81*0.1=0.981
200g= 9.81*0.2=1.962
300g= 9.81*0.3=2.943
Speed:
100g= 39 m/s
200g= 54 m/s
300g= 72 m/s
µ values:
100g -> 0.981/39^2 = 644.9*10^-6 kg/m
200g -> 1.962/54^2 = 672*10^-6 kg/m
300g -> 567.7*10^-6 kg/m
Do i like average the tension and speed values and subtract the max and min number
So if i do that then:
average of tension = 1.962
2.943-0.981=1.962 <- this is the uncertainty?
average of c^2:
  • averaging -> 39+54+72/3 =55
  • squaring -> 55^2 = 3025
72-39= 33
72^2-39^2=3663
This seems very wrong i don't really know what I'm doing.
Likes ephphatha16
You absolutely do not average the tensions or the speeds. You average only quantities that are supposed to be the same in order to reduce the uncertainty in the measurements. Since the speed depends on the load, you can average the speeds that you get with the same load for different harmonics. That would make sense. It makes no sense to average speeds for different loads because you know they are different and you know why they are different so what good would it do to you if you average them?
You say you understand the basics of error propagation. You have quoted the uncertainties in f, L and λ. How about the uncertainty in FT? Can you estimate that? If so, find an expression for μ in terms of the experimentally measured quantities and do error propagation analysis. Also note that you have 15 measurements you can use to calculate 15 values of μ separately. Find what these are and see if they are consistent with the error propagation anlysis.
Likes ephphatha16
Related to Error calculation for µ in standing wave experiment
1. How do you calculate the error for µ in a standing wave experiment?
The error for µ in a standing wave experiment can be calculated using the formula: Δµ = λ²/4L, where λ is the wavelength of the standing wave and L is the length of the experiment.
2. What is the significance of calculating the error for µ in a standing wave experiment?
Calculating the error for µ allows us to determine the precision and accuracy of our experimental results. It also helps us understand the reliability of our measurements and the potential sources of error in the experiment.
3. How can the error for µ be minimized in a standing wave experiment?
The error for µ can be minimized by using precise and accurate measurement tools, such as a ruler or caliper, and ensuring that the experiment is set up and conducted consistently. Additionally, taking multiple measurements and averaging the results can also help reduce errors.
4. Can the error for µ be negative in a standing wave experiment?
No, the error for µ cannot be negative as it represents the difference between the calculated value of µ and the accepted or expected value.
5. What are some common sources of error in a standing wave experiment that can affect the calculation of µ?
Some common sources of error in a standing wave experiment include human error in measurement and reading instruments, variations in the tension and length of the string used, and environmental factors such as temperature and humidity. Improper setup and alignment of the experiment can also introduce errors in the calculation of µ.
15K
