Error in perturbation series question
In summary, if the perturbation series E = E(\epsilon) = E_0 + \epsilon E_1 + \epsilon^2 E_2 + \ldots converges, then it is possible to show that E - E_0 = O(\epsilon) as \epsilon \to 0. This means that there exists a \delta > 0 and a C > 0 such that if |\epsilon| < \delta, then |E - E_0| \leq C|\epsilon|. However, perturbation series are typically asymptotic series and do not converge, so this statement may not hold in general.
AxiomOfChoice
533
Suppose we know the perturbation series
[tex]
[/tex]
converges, where [itex]E_0[/itex] is a discrete eigenvalue of [itex]H_0[/itex] and we are considering a Hamiltonian [itex]H = H_0 + \epsilon H_1[/itex]. Does this mean that we know
[tex]
[/tex]
as [itex]\epsilon \to 0[/itex] in the precise sense that we know there exists a [itex]\delta > 0[/itex] and a [itex]C > 0[/itex] such that if [itex]|\epsilon| < \delta[/itex], then [itex]|E - E_0| \leq C|\epsilon|[/itex]?
If the perturbation series converges, this C has to exist - that is just mathematics (taylor series).
If you really have a convergent series, then I think your statement holds just as a general property of power series, and you can pick any ##C > |E_1|##. As I understand it, however, perturbation series typically do *not* converge. They are usually asymptotic series, meaning that if you truncate them after order ##\epsilon^N##, the error between the truncated series and the actual eigenvalue vanishes like ##\epsilon^{N+1}## as ##\epsilon \to 0## (which statement you can formalize if you like in the same epsilon-delta style).
FAQ: Error in perturbation series question
What is an error in perturbation series?
An error in perturbation series refers to the difference between the exact solution of a mathematical problem and its approximate solution obtained through a perturbation series. It is a measure of the accuracy of the approximation and can be caused by various factors such as truncation of the series and round-off errors.
How is the error in perturbation series calculated?
The error in perturbation series is typically calculated using the difference between the exact solution and the approximate solution, divided by the exact solution and multiplied by 100 to get a percentage. This is known as the relative error and is a common way to measure the accuracy of an approximation.
What are some common sources of error in perturbation series?
Some common sources of error in perturbation series include truncation of the series, which is when only a finite number of terms are used in the approximation, leading to an incomplete representation of the solution. Round-off errors, which are caused by the limitations of computer arithmetic, can also contribute to the overall error.
How can the error in perturbation series be minimized?
To minimize the error in perturbation series, it is important to use a higher number of terms in the approximation, which can improve the accuracy of the solution. Additionally, using more precise arithmetic and rounding techniques can help reduce the impact of round-off errors. In some cases, using alternative methods such as numerical integration can also help minimize error.
Are there any limitations to using perturbation series for solving problems?
Yes, there are limitations to using perturbation series for solving problems. This method is only applicable to problems that can be expressed as a series expansion, and the series must converge for the approximation to be accurate. Additionally, for problems with multiple sources of error, perturbation series may not be the most suitable approach and other methods may need to be used.
