Error in the average of same-value measures
In summary, the conversation discusses the error in averaging the three measurements of the radius of a sphere taken with a micrometer of 0.01 mm resolution. The question is whether the error of the average should be the same as the error of each individual measurement. The NIST guideline on uncertainty is referenced and it is explained that the type A uncertainty is 0, and the type B uncertainty is obtained through knowledge of the device characteristics. The appropriate model for the type B uncertainty is a uniform distribution, and according to the NIST reference, the type B standard uncertainty is 0.005/sqrt(3). The total estimated standard uncertainty is calculated by adding the type A and type B uncertainties using the square root of the sum of squares
Guilherme Franco
My question is simple, and I'm only asking it because most places talk about more advanced problems than this one:
I've measured the radius of a sphere (a very regular one) with a micrometer of 0.01 mm resolution.
I took 3 measures (rotating it between each measure), and all of them were perfectly the same value: 19.23 mm . It was not only the same value, but the lines coincided perfectly on the three.
Each measure is noted as 19.230 mm +- 0.005 mm, however, when averaging the three values (what gives the same value as result), what should be the error of the average?
If I sum up the three measures (propagating the error in the sum) and then divide the result by 3, I get an error of +- 0.002886751 mm (+- 0.003 mm rounding it to a single significant figure).
Is this correct?
Thanks!
I think that you are correct because your measures were close to 0.005mm which is honestly extremely close to 0.003mm.
I am no expert, but I disagree. If you were adding up three figures with independent random errors then the relative error in the mean would (roughly speaking) be estimated by the relative error per measurement divided by the square root of three. But we are talking about quantization errors here. Are those independent? If the object is truly a sphere and the measurements are truly accurate to the precision of the instrument then the answer is no. They are not independent random errors. An error estimate that treats them as if they were is incorrect.
Then you are not going to get better than 0.01 mm by measuring multiple times. The only thing multiple measurements will help constrain is the average diameter for a sphere with measurable non-sphericity.
This is what I would call a deceptively simple question! It is simple, but it is easy to get it wrong. I would say that the definitive reference is the NIST guideline on uncertainty:
https://www.nist.gov/sites/default/files/documents/2017/05/09/tn1297s.pdf
However, if this is for a class and your teacher uses a different method then by all means learn your teacher’s method.
So, if you read the NIST reference then you see that you will have a type A uncertainty that you obtain through statistical methods and a type B uncertainty obtained through knowledge of the device characteristics.
The type A uncertainty is given by the sample standard deviation, which is 0. So the type A standard uncertainty is 0.
For the type B uncertainty your +-0.005 value means that your measuring device will report 19.23 for any value from 19.225 to 19.235. So the appropriate model is a uniform distribution over that range. So according to the NIST reference that gives a type B standard uncertainty of 0.005/sqrt(3). Note, the factor of sqrt(3) has nothing to do with the three samples you took, it is just due to the uniform distribution of your type B uncertainty.
To get your total estimated standard uncertainty you add the type A and type B uncertainties using the square root of the sum of squares. Since type A is 0, then this is just equal to the type B.
Interestingly, in my case, if I sum up all measures (propagating the error to the sum) and then divide everything by 3 (the value and the error), I get to the exact same value of 0.005/sqrt(3), because the error would be sqrt(3*(0.005²))/3 doing like that.
Just a coincidence though, if I tried that same method with another amount of measures it wouldn't be the same result.
Likes Dale
Yes, exactly!
Related to Error in the average of same-value measures
What is "Error in the average of same-value measures"?
"Error in the average of same-value measures" refers to the discrepancy or variation in the average value of repeated measurements of the same quantity. This type of error can occur due to various factors such as measurement inaccuracies, experimental errors, and natural variability of the measured quantity.
Why is it important to understand and address this type of error?
Understanding and addressing the error in the average of same-value measures is crucial for ensuring the accuracy and reliability of scientific data. It helps to identify and eliminate any sources of error, leading to more precise and valid conclusions.
How can you calculate and minimize this type of error?
This type of error can be calculated by taking the difference between each measurement and the average, and then finding the average of those differences. To minimize this error, scientists can use more precise measurement tools, conduct multiple trials, and implement proper experimental controls.
What are some common sources of error in the average of same-value measures?
Some common sources of error in the average of same-value measures include human error, equipment limitations, environmental factors, and inherent variability of the measured quantity.
How can you determine if the error in the average of same-value measures is acceptable or significant?
The acceptability or significance of the error in the average of same-value measures depends on the specific context and purpose of the experiment. Scientists can compare the magnitude of the error to the precision and sensitivity of their measurement tools, as well as consider the potential impact of the error on their conclusions.
  • Other Physics Topics
