Fortran Errors in Fortran code for solving Laplace's equation in 3D
The discussion revolves around a Fortran program designed to solve the Laplace equation within a cubic domain, focusing on boundary conditions and potential values. The user encountered two main errors while testing the code with different cube dimensions. The first error, related to a 3x3x3 cube, was due to uninitialized array elements in the PHI array, specifically at index positions that were not set in the initialization subroutine. The second error occurred when attempting to allocate memory for a 10x10x10 cube, which resulted in an allocation failure because the program attempted to create excessively large arrays (1000x1000x1000) due to the DELTA value of 0.01. This led to a request for guidance on suitable input values to avoid such errors. Suggestions included adjusting DELTA and ensuring proper initialization of the PHI array to resolve the issues.
physicsuser2023
TL;DR Summary
I encountered errors while running a Fortran code to calculate potential values inside a cube, with the first error being a reference to an undefined variable and the second error being insufficient storage allocation.
hey everyone. I wrote a code in Fortran to calculate potential values or solve the Laplace equation inside a cube according to the boundary conditions mentioned in the code.
this is my code:
Fortran:
program laplace_cubic
  implicit none
  REAL*8 :: LX, LY, LZ, DELTA, MAX_ERR, ERR
  INTEGER :: NX, NY, NZ, I, J, K, M
  INTEGER*8 :: MAX_COUNT
  REAL*8, DIMENSION(:,:,:), ALLOCATABLE :: PHI, PHIO
  write(*, *) 'LX='
  read(*, *) LX
  write(*, *) 'LY='
  read(*, *) LY
  write(*, *) 'LZ='
  read(*, *) LZ
  write(*, *) 'ENTER MAX COUNTER='
  read(*, *) MAX_COUNT
  write(*, *) 'ENTER MAX ERROR='
  read(*, *) MAX_ERR
  DELTA = 0.01
  NX = INT(LX/DELTA)
  NY = INT(LY/DELTA)
  NZ = INT(LZ/DELTA)
  ALLOCATE(PHI(0:NX, 0:NY, 0:NZ))
  ALLOCATE(PHIO(0:NX, 0:NY, 0:NZ))
  CALL INITIALIZE(PHI, NX, NY, NZ, LX, LY, LZ, DELTA)
DO M = 1, MAX_COUNT
    PHIO=PHI
    ERR=0.0
    DO I = 1, NX - 1
      DO J = 1, NY - 1
        DO K = 1, NZ - 1
          PHI(I, J, K) = (PHIO(I + 1, J, K) + PHIO(I - 1, J, K) + PHIO(I, J + 1, K) + &
               PHIO(I, J - 1, K) + PHIO(I, J, K + 1) + PHIO(I, J, K - 1)) / 6.0
          ERR = ERR + (PHI(I, J, K) - PHIO(I, J, K))**2
        END DO
      END DO
    END DO
    IF (ERR < MAX_ERR) EXIT
END DO
OPEN(100, FILE = 'laplaceoutput.TXT')
  DO I = 0, NX
    DO J = 0, NY
      DO K = 0, NZ
        WRITE(100, *) I * DELTA, J * DELTA, K * DELTA, PHI(I, J, K)
      END DO
    END DO
  END DO
end program laplace_cubic
SUBROUTINE INITIALIZE(PHI,NX,NY,NZ,LX,LY,LZ,DELTA)
    IMPLICIT NONE
    REAL,PARAMETER::PI=3.1415
    INTEGER::I,J,K
    INTEGER,INTENT(IN)::NX,NY,NZ
    REAL*8::DELTA,X,Y,Z,LX,LY,LZ
    REAL*8,DIMENSION(0:NX,0:NY,0:NZ)::PHI
DO J = 1, NY - 1
  DO K = 1, NZ - 1
    PHI(0, J, K) = 1.0  ! potential inside the back face (zy plane)
    PHI(NX,J,K) = 0.0
  END DO
END DO
DO J = 0, NY
  Y = J * DELTA
  PHI(0, J, 0) = SIN(PI*Y/LY)  !sinusoidal potential along y-axis
END DO
DO K = 0, NZ
  Z = K * DELTA
  PHI(0, 0, K) = SIN(PI*Z/LZ)  ! sinusoidal potential along z-axis
END DO
DO J = 1, NY-1
  DO I = 1, NX-1
    PHI(I, J, 0) = 1.0  ! potential inside the bottom face (xy plane)
    PHI(I,J,NZ) = 0.0
  END DO
END DO
DO I = 0, NX
   X= I * DELTA
  PHI(I, 0, 0) = SIN(PI*X/LX)  ! sinusoidal potential along x-axis
END DO
DO I = 1, NX-1
  DO K = 1, NZ-1
    PHI(I, 0, K) = 1.0  ! potential inside the left face (XZ plane)
    PHI(I,NY,K) = 0.0
  END DO
END DO
DO K = 1, NZ-1
  DO J = 1, NY-1
    DO I = 1, NX-1
      PHI(I, J, K) = 0.5  ! potential inside the cube
    END DO
  END DO
END DO
END SUBROUTINE INITIALIZE
I first entered the dimensions of the cube as 3x3x3, Iteration or MAX COUNTER as 1000, and MAX ERROR as 0.000001. After these inputs, I enter to make the program perform the operation, but it showed me an error: error 112, reference to undefined variable, array element or function result.
I then set the dimensions of the cube to 10x10x10 and the rest of the inputs the same as before. But this time I received another error: ALLOCATE was unable to obtain sufficient storage.
I tested a code similar to the above code for the two-dimensional case and it worked.
what's the solution?
Technology news on Phys.org
With DELTA at .01, 10x10x10 results in both PHI and PHI0 arrays being dimensioned 1000x1000x1000.
So you were trying to allocate memory for 2 billion real values (16,000,000,000 bytes). So there is no mystery about the allocation error.
For the other error, it will be a lot easier to track down if you note where this error occurred in the code. I don't know what debug tools you have, but at a minimum, you can run the code after putting some "WRITE(*,*) 'at line #999' statements in.
Likes Vanadium 50 and physicsuser2023
Thank you for your guidance. Now I understand that the error related to 10*10*10 is a normal and reasonable thing. So can you suggest me some suitable input values to fix this error? Values for delta and other inputs. thanks
But the error related to 3*3*3. its said there is in line 32
OK. So you have not fully initialized PHI. Some of the 301x301x301 entries in that array were not set in function INITIALIZE. On the face of it, it appears that you are never setting array elements with indexes of 300.
In Fortran, an array of 0:N has N+1 elements.
(So my calculation above should have been (1001x1001x1001).)
Likes physicsuser2023
Thank you for guidance, i check the code again
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
9K
