Escape velocity and Dark Matter
In summary: Earth's surface needs to attain to escape Earth's gravitational pull is 11.2 km/s. This takes into account Earth's mass and radius.However, this equation does not take into account other factors, such as dark matter, air resistance, and fuel leeway for rockets. It has been verified to be accurate enough for practical use, as demonstrated by the success of space missions. Other theories, such as MOND and General Relativity, have been proposed to possibly explain the discrepancies in the velocity curves of stars at the edge of galaxies, but the Newtonian escape velocity equation remains a reliable and practical tool for space exploration.
Zman
96
I was wondering how verifiable is the escape velocity equation.
V=SQRT(2GM/r)
How accurately has this equation been verified?
It does not take into account dark matter.
(Related ramblings)
The escape velocity from the earth’s surface is about 11.2 km/s
But there is also air resistance. How much extra velocity (above 11.2 km/s) is required to escape Earth’s gravity?
I am not after a specific value, I would just like to know if the energy requirement increase is significant or not.
How much leeway in terms of fuel does NASA give when firing rockets into space?
V=SQRT(2GM/r)
It's a consequence of Newtonian physics, and so it has been verified to the extent that Newtonian physics has been verified... pretty darn accurate.
The M refers to matter, whether it be dark or baryonic or anything else. A more correct statement is that it does not make any distinction between what kind of matter is involved. Nor should it.
(Related ramblings)
That's an odd question... air resistance will depend on the shape of the projectile, so there's no one answer. And it is not relevant anyway. We put things into space not by giving them an escape velocity at the surface, but by using a rocket that keeps powering up all the way to orbit or beyond. The escape velocity would be more relevant if you had a gun or other sudden impulse applied at the surface of an airless planet.
I don't think it is all that significant. I don't think air resistance makes all that much difference for a rocket. It would make some difference, of course; but the rocket is shaped to keep the air resistance small, and it soon gets up into pretty thin atmosphere.
But don't quote me on that. I can't given you a specific number... so it's good you didn't ask for one.:redface:
Not much, I think. Something like the shuttle is placed into orbit mainly by boosters that are discarded. It carries more fuel for maneuvers in orbit; but the amount of fuel to get into orbit doesn't change enough to make "leeway" something to worry about.
Cheers -- sylas
Thanks Sylas
I was also thinking about MOND but maybe you have answered that question already.
With escape velocity, it can be derived using Potential Energy at the Earth’s surface with reference to infinity and equating it to kinetic energy.
But surely we have never tested dropping a body from infinity to the surface of a large mass?
This doesn’t detract from all the confirmation we have regarding Newtonian physics.
But when we talk about potentially large distances, do we not get general relativity issues that could alter the escape velocity equation?
Cheers Zman
Differences are negligible. Same for MOND. The Newtonian approximation is plenty accurate enough, particularly if you are concerned with air resistance or other non-gravity related factors. Those factors are much more significant than the tiny differences between GR, MOND and Newton applied to escape velocity from the Earth.
I am not sure how to do "escape velocity" in GR. It will depend on co-ordinates, I guess. There should be a suitable equation for a lightweight particle measured by a stationary local observer, I would think. I don't know what it is, or if it is different from the Newtonian equation.
Cheers -- sylas
Thanks again
I am changing the goal posts slightly here as I think that my thoughts on this issue are a bit clearer.
We know that velocity curves of stars are greater than expected at the edge of the galaxy. We also know that there must be a bigger gravity than Newton’s to keep the stars from flying out.
If a small mass was dropped from such a location towards the centre of the galaxy a slight increase in gravity would be compounded as a large increase in velocity.
The Newtonian escape velocity equation would surely give too small a result.
Cheers Zman
Actually, Newton gravity is just fine... as long as there is more matter in a galaxy than we can see in the form of stars and dust. That is, a galaxy might have a lot of "dark matter", in which case the equations all continue to work as usual.
There are other reasons to suspect that this is the case; but it's still worth looking at other possibilities. MOND was a possible alternative, although that doesn't work well for explaining gravitational lensing seen in deep space.
Cheers -- sylas
V=SQRT(2GM/r). How accurately has this equation been verified?
Math based on this equation has been used to successfully sent satellites to other planets, as well as put a few men on the moon and return them. Apollo mission involved exceeding escape velocity to reduce the time it took to get into lunar orbit (which required using thrust to slow it down again). On the return trips, Apollo again exceeded escape velocity, but was aimed to hit Earth atmosphere at the correct angle to slow it down without burning it up.
From the Earth's surface, because of the atmoshpere, it's unlikely to achieve escape velocity because just about any real object with mass would burn up before achieving the required speed.
Related to Escape velocity and Dark Matter
1. What is escape velocity and how is it calculated?
Escape velocity is the minimum velocity required for an object to overcome the gravitational pull of a larger object and escape its gravitational field. It is calculated using the formula: v = √ (2GM/r), where G is the gravitational constant, M is the mass of the larger object, and r is the distance between the two objects.
2. Can escape velocity be exceeded?
Yes, escape velocity can be exceeded if an object receives additional force or acceleration. This can happen, for example, if a spacecraft uses a gravitational slingshot technique around a planet to gain speed and exceed its escape velocity.
3. How does escape velocity differ on different planets?
The escape velocity on a planet is dependent on its mass and radius. Generally, the larger the planet, the higher its escape velocity. For example, the escape velocity on Earth is 11.2 km/s, while on the smaller Mars it is only 5 km/s.
4. What is dark matter and why is it important?
Dark matter is a type of matter that does not interact with light or other forms of electromagnetic radiation, making it invisible to telescopes. Its existence is inferred through its gravitational effects on visible matter. It is important because it makes up around 85% of the total mass of the universe and plays a crucial role in the formation and evolution of galaxies.
5. How is dark matter detected and studied?
Dark matter cannot be directly observed, so scientists use various techniques to indirectly detect and study its effects. These include observing the rotation of galaxies, studying gravitational lensing, and looking for signals from particle collisions in high-energy experiments such as the Large Hadron Collider. Further research and experiments are ongoing to better understand the nature of dark matter.
  • Astronomy and Astrophysics
  • Mechanics
  • Mechanics
